Amp for SDA 2B's
chandler9a
Hello, I enjoy all of the information on this forum regarding the wonderful SDA line.
I was wondering if anyone had some information of whether or not the NAD 2400 or 2700 two channel amps would A: be a good match for my sda 2b's? and B: are they common ground so as to actually work with them at all?
I am also considering the Adcom GFA 545.
Any advice would be greatly appreciated
Thanks!
Thanks!
Post edited by chandler9a on
I dont think the 545 is common ground and if not you can tie the neg posts to make it soSDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
I have the Adcom 555, 545 and 5400, all are common ground.
I also have the NAD 3400PE integrated, which uses the same 2400 amp. This NAD is also common ground. I have driven a pair of SDA 1Bs with the Adcom 555, but have since moved them to a room of their own driven with the NAD 3400 which really opens them up. The Adcom sounded great, but I do like the NAD much better.David -
I currently run the SDA's off a Sonny 555es which I love. I think its around 110 wpc, but I am assuming the NAD 2400 would be a significant improvement.
any thoughts?
-Aaron -
Thanks for all of the info! I ended up going with the GFA-555. I wanted a little more power
davidk0512 wrote: »I have the Adcom 555, 545 and 5400, all are common ground.
I am positive the Adcom 5400 is NOT common ground.
