Keep ADCOMS or New EMOTIVA'S
mark g. nelson
mark g. nelson Posts: 134
edited January 2009 in Electronics
I currently have a GFA 7500 and a 5400. I have liked them alot. But the upgrade bug has hit and I'm getting a new Pre/Pro. Either the Marantz 8003 or Integra 9.9.
Would the amp change improve what I have ? I would get the XPA-5 and XPA-2.
I also will need a new blu ray. Have any of you tried the new Marantz or Integra offerings?
Thanks for any input you might have.
Mark
Post edited by mark g. nelson on
  • Early B.
    Early B. Posts: 7,900
    edited January 2009
    The Emotiva gear will be a big step ahead of the Adcoms.
    "God grooves with tubes."
  • mark g. nelson
    edited January 2009
    Thanks Early B.
    I also had a thought about which models to get.
    the XPA-5 looks great but on the XPA- 2, overkill for rear surrounds?
    So I was thinking about just the UPA-2. But I would lose the XLR inputs how important are they? I aslo thought the UPA-7 would work but less power then I already have.
    any thoughts. Thanks
  • ben62670
    ben62670 Posts: 15,969
    edited January 2009
    Emo has great gear for the price and comes with a warranty. I had a 7500, and a 5400 both are great cheap amps that can drive very low impedance speakers like LSI's. I am not a huge fan of newer Adcom's aside from the 5800, and 5802. Not all amps are designed to take advantage of balanced inputs;) Most of the lower priced units just convert the balanced signal to an unbalanced signal within the amp. Longer runs can take advantage of balanced cables. You can run good unbalanced cables at 8 feet no problem. IMHO EMO would be a lateral move especially if you were wanting to be able to drive low impedance speakers in the future.
    Ben
  • mmadden28
    mmadden28 Posts: 4,283
    edited January 2009
    If you go with that pairing, definitely put the XPA-2s on the mains. Use the XPA-5 for the rest. The XPA-2 is a different, better design than the XPA-5--its not just 3 less channels.
    ____________________
    Pool: Atrium 60's/45's
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited January 2009
    mmadden28 wrote: »
    If you go with that pairing, definitely put the XPA-2s on the mains. Use the XPA-5 for the rest. The XPA-2 is a different better design that the XPA-5--its not just 3 more channels.
    x2. The XPA-2 would be better suited driving your mains, with the XPA-5 taking care of the surrounds/center channel.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • brettw22
    brettw22 Posts: 7,623
    edited January 2009
    Get the XPA-3 which is currently on sale for $150 off and is the same power rating all around.......I don't see the reasoning for having 50wpc more to whichever speakers you have hooked up to the XPA-2.
  • mark g. nelson
    edited January 2009
    I was just thinking the same thing.
    I see your from SLC. How about those UTES!!!
  • bigred7078
    bigred7078 Posts: 477
    edited January 2009
    brettw22 wrote: »
    lol the only difference isnt 50 watts. It excells in 2-channel performance and will really give an extra oomph for your speakers compared to the XPA-5
    But i will agree if your not wanting to spend alot the XPA-3 is a powerhouse! I love mine
    Pro-ject RM-9.1 w/ Grado Sonata 1 -> USP-1 -> RPA-1 -> Vienna Acoustics Mozart Grands
  • engtaz
    engtaz Posts: 7,665
    edited January 2009
    Thanks Early B.
    If your going with the Marantz then get amp with XLR inputs. From there you can decide on which amp to go with. Most power needed is in the front 3 speakers.
    engtaz
    engtaz
