Don't know how to summarize my question, so I'll type this instead......
brettw22
brettw22 Posts: 7,624
edited October 2008 in Car Audio & Electronics
OK, I have 2 pairs of SR6500's (F & R's) in my Accord and at lower volumes i hear virtually little to no sound from the front speakers (even though I have them set to F06 on the fade). When I turn the volume up I obviously get more sound then it sounds more even between the front and rears.....
Is there anything that I can really do to get the sound boosted at lower volumes in the front? Is that something I need to adjust on the amp? Not having looked at the amps for a while, I have no idea if there are separate gains for each channel or whatever......
One downside to the way these were installed is that the Tweet and Mid's are in the lower door panel, so I know I'm not going to hear as much compared to the tweet being in the dash, but I wasn't in the mood to have someone else put the tweet up there......lol......
Post edited by brettw22 on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited October 2008
    It is your added trunk loading and rear glass reflection gain that makes your rears louder. Gain adjustments on the amps or fader should help. Try for a fat front with rears simply used to fill in the gaps of sound. Your fronts being in small door cavities are no match for the trunk space for bass loading.
  • dirthog
    dirthog Posts: 124
    edited October 2008
    Also try turning your tweeter down in the rear at the crossover. Upper frequencies are easier to locate.
    HU: 880PRS
    Front: SR6500
    Amp: Alpine MRV-F545
    Sub: SR124-DVC
    Amp: Alpine MRD-M1005
  • tk421
    tk421 Posts: 156
    edited October 2008
    or the rear speakers have a higher sensitivity
  • PolkThug
    PolkThug Posts: 7,532
    edited October 2008
    Are you using the factory, or aftermarket HU?
  • brettw22
    edited October 2008
    Aftermarket......it's a Pioneer Premier p860-MP (or something like that)
  • MacLeod
    MacLeod Posts: 14,358
    edited October 2008
    Check the gains on the amp(s). Make sure the front gain is set higher than then rear gain.
  • eloplayspolo
    eloplayspolo Posts: 1,117
    edited October 2008
    and if ur front is at +6... but u hear ur rears... ur RCAs may be switched somewhere
    2013 Toyota Prius
    Audible Physics 3 Way: H6MB, AR3-A, AR2.0
    Image Dynamics iDMax 12" D2v4
    (2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
    Mosconi 6to8 v8
  • brettw22
    edited October 2008
    I'm sure it has to do with the gains......just have to find some time to do that....fun.
    I'm not saying I hear nothing from the fronts.......just that at lower volumes the front is barely noticeable, but when things are turned up is when I hear them more (albeit due to a +6 F setting).........
