Which Polk Center Channel Speaker to go with old SDA2a's?
thragus
thragus Posts: 2
edited July 2008 in Speakers
I've been using an old Polk 4A Monitor speaker as my center channel for awhile, and I would like to get a center channel that matches the Polk SDA 2a's which I have as left and right speakers. This could be an old or new model. I just want to match the SDA 2A as much as possible. Thanks for any help.
Dave
Post edited by thragus on
  • Frank840
    Frank840 Posts: 262
    edited July 2008
    http://www.polkaudio.com/education/showanswer.php?question_num=63
    there you go boss . Looks like the CSI5 is the winner
    Frank
    - This your Bush?
    Pioneer Elite Sc-25
    Polk Lsic,15's,9's, PSW1000
  • ben62670
    ben62670 Posts: 15,969
    edited July 2008
    First welcome to club Polk. A lot of guys don't use a center channel with SDA's. If the SDA's are set up properly I feel you don't need one. This is just an opinion. The SDA crowd is probably at 50/50 on this one.
    Ben
    Ben
  • Ron Temple
    Ron Temple Posts: 3,212
    edited July 2008
    CS400/400i or the LSiC are the closest timbre matches.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • thragus
    thragus Posts: 2
    edited July 2008
    Hmmm, I've been thinking about going with the LSiC with the thought that I would eventually upgrade the surrounds with the LSi series, but now I don't have the money and want to get by cheaper. I haven't tried not using a center channel with movies. I might give that a try. Can you just blend the center into the left and right? Thanks for the suggestions everyone.
    Dave
