Vintage Soundcraftsmen amp. pre/eq, and tuner, Monitor 10's
Boywonder
Vintage Soundcraftsmen A2502 power amp. 125W rms into 8 ohms, 250W rms into 4 ohms. Lots of LEDs for power output and clipping indication (LEDs indicate 250W/500W peak before clipping) Excellent Condition, works great, no issues. Made in USA (Santa Ana, CA) Has separate volume controls for each channel, one set of RCA inputs, and two sets of speaker outputs. I believe that this is a mosfet amp. $180+Shipping
Vintage Soundcraftsmen CX4200 preamp/eq and T6002 tuner. The preamp has lots of knobs and sliders, two phono inputs with rear dip switches for cartridge load. Removable Oak Veneer sides, rack mountable. Excellent condition, works great. Preamp is made in Santa Ana, CA. Soundcraftsmen T6002 tuner, later model, made in Korea, black, digital, 1U rack mountable. $125+shipping for both preamp and tuner.
Polk Monitor 10s with SL2000s, oak vinyl, great shape, local pickup in Orange County, CA only. I will post pics shortly. $120
Post edited by Boywonder on
Holy LED's batman. Interesting piece of equipment....good luck.
where do you live mate?
DO you know if the amp is bridgeable?
Not internally, but you can bridge 2 A2502's with soundcraftsmen's AB-1 bridger.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2 -
I am in Orange County, CA., South County-Coto De Caza or Irvine
I don't know if the amp is bridgable, if it is, it's not obvious. I found some specs below from the AK forum, I think the "L" im L2502 refers to the LEDs (some amps came plain-jane no LEDs) It's actually 190W rms into 4 ohms according to the AK page.
Here is a link to the page:
http://www.audiokarma.org/forums/archive/index.php/t-116658.html
These are cut and paste specs from an AK member.
Some info for you on the LA2502 Amp
Continuous Average Power Output
190 Watts 20HZ to 20Khz 4 Ohms
125 Watts 20HZ to 20Khz 8 Ohms
THD Typical less than .02%
Freq Resp Plus or minus 1/4dB 20HZ to 2OKHZ
I.M. Distortion 60Hz/7KHZ less than .005%
T.I.M distortion Less than .02 %
Signal to Noise Ratio > 150
Input Impedance 32K Ohms
Stability Any load 2 Ohms or Greater
Size 5 1/4 X 19 X 15
Shipping Weight 30 Pounds
Basicly this is Half of a MA5002A
375 Watts 20HZ to 20Khz 4 Ohms
250 Watts 20HZ to 20Khz 8 Ohms
Size 7 X 19 X 15
Shipping Weight 55 Pounds -
I'd be all over this amp if I needed one. See my above post regarding bridging. I owned the Soundcraftsmen A5002 and 2 PM840's (bridged) thru the years, excellent amplifiers.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
Here are pics of the monitor 10's and the tuner:
Boywonder that is some very nice equipment you have. Looks Great.
Good luck,
engtazengtaz
bump
