Center Channel for 1.2tl's - opinions
Bullet21
I have some Monitor 7's I could upgrade the crossover and the tweeter and use one or get an LSI Center - any opinions????
I added the picture of the model 7 crossover - probably should upgrade it just for fun... any suggestions are appreciated.
Post edited by Bullet21 on
I am using 2 lsic's with the 1.2's (not tl's, not upgraded). I can run the two speakers at the same volume as the mains and they are not being pushed. I use two because I just put together a HT with a 106" screen and I wanted to make sure that the centers were providing a little broader soundstage. I can honestly say that with just one it seemed as though the sound was a little too focal pointed, the broader soundstage idea with two seems to work. It's probably just me justifying. I did use a klipsch center before and the lsic are clearly a better match to the 1.2's.......
I haven't calibrated the sysem yet that will be done by the end of this week and if I notice any significant changes I'll get back to you.
FWIWHome Theater
Amp: sunfire cinema grand signature 5ch 425 wpc
Side surround amp: Sunfire 2 X 300
Processor: sunfire theater grand V
Fronts:: polk sda-srs 1.2
Rears: Polk LSiFX
Side surrounds: Fxi5
Center: (2)polk LSiC's
Sub: svs pb-13 rosenut
Hd-Dvd: toshiba xa-2
Blue Ray: oppo bdp83se
Projector: sony vw60
Screen: Da-Lite 106"
APC S20 Power conditioner -
I'm trying NO center channel for a few weeks. So far, I don't miss it.
