Old 78's... cleaning and worth anything these days?
MrNightly
My parents and my grandparents have a bunch of old 78's and records, and we didn't know if they were worth anything these days, so I figured I'd ask around.
Also, how do you clean them?
Honoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
SVS PB12-NSD/2 - sub
Denon 3805
Rotel RB-985 5-Channel Amplifier
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
Denon 3805
Post edited by MrNightly on
Yes they can be worth something.
You can use any kind of record cleaner that is not alcohol based. Alcohol will melt them and kill you from the fumes.
PM Madmax as he has done some cleaning of 78s of late. -
Easy to clean. As HI says use non-alcohol based cleaner. The steamer we have been using works ok with them. I run mine on the VPI vacuum cleaner. You must be careful with them as they are very brittle and crack if you do not have them on a solid flat surface while cleaning them. Probably a cheap record cleaning kit would work ok for $30. I've heard some say not to use water as it sucks into the substrate of the disc and molds but don't really know much about that. I've still steamed some of mine.
At the antique shops they tend to go for 75 cents to $1.50, with the chosen few being maybe $2-$5. On ebay you can find lots of 50 or more for maybe .20 each.
If you decide to get rid of them I might be interested depending on what they are.
I would snap them in half so they fit in the garbage can better.
As aforementioned, they are usually very brittle so handle with care.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
You're just scared.
Come up to my place sometime. I want to tie you to my listening chair and torture you with vinyl and Carver.
:D Wristwatch--->Crisco -
hearingimpared wrote: »and kill you from the fumes.
and you would be dead just like the artists on the records.
You're just scared.
:D
I'll help!!!:D -
I gotta tell you . . . my cousin has a shitload of 78s, I mean crates full of The Great Caruso and other really famous, awesome tenors and sopranos. Believe it or not they sound friggin great. He plays them through one of those antique Victrolas. No amplification back then just a mike, and a big megaphone for playback. -
hearingimpared wrote: »I gotta tell you . . . my cousin has a shitload of 78s, I mean crates full of The Great Caruso and other really famous, awesome tenors and sopranos. Believe it or not they sound friggin great. He plays them through one of those antique Victrolas. No amplification back then just a mike, and a big megaphone for playback.
Its a trip isn't it? Puts you in a different place.
