Best Amp For Lsi25 9's Lsic
jparker82
jparker82 Posts: 54
edited November 2007 in Speakers
What Would Be The Best Amp To Use To Power These Monsters. I Purchased A Nad T973 And I Am Not Very Happy With It--- I Need More Power. It's Only 7 X 140wpc. My Current Receiver(yammy) Has The Same. I Don't Really Want To Go Outlaw. But I Don't Really Want To Drop 8000 On A Krell. I Really Don't Know If The Amp Just Pumps To Signal It Is Sent. Or Does It Change It??? If Some One Wants My Nad It's On Audiogone For 1199 Obo.(want It Gone)
Onkyo Tx Nr 5007
Integra NAS 2.3 audio serv
Intergra DHS 8.8 HD-DVD
Integra NVS 7.7 Home Theater Media Compt
Anthem MCA 20
Integra 70.1 9 channel amp
OPPO 93 BLU RAY
Monster HDP-2400 power cond
Panamax M5300 PM
Monster HtS-2600 Power cond
Samsung 8000 series e64 plasma
Polk LSI 25
Polk LSI center
Polk LSI 9
Polk LSI 7
Polk LSIM702 fx
Boston Acoustic in ceil #'s ???
Definitive tech sub
Nordost Blue Heaven Rev2 BI wire(great cords)
2 other systems master and pool area
Post edited by jparker82 on
  • phuz
    phuz Posts: 2,372
    The NAD should be fine. Look into other parts of your system if you are not happy.
    Assuming you're using your Yammy with the amp, maybe try a real pre/pro.
  • jparker82
    jparker82 Posts: 54
    Phuz,
    Everyone States That I Need 4ohms To Push The Lsi's. I Have A Hugh Room And I Am Just Not Getting What I Want. Very Happy With Everything Else In My System.
    Onkyo Tx Nr 5007
    Anthem MCA 20
    OPPO 93 BLU RAY
    Panamax M5300 PM
    Polk LSI 25
    Polk LSI center
    Polk LSI 9
    Polk LSI 7
    Polk LSIM702 fx
    Definitive tech sub
  • engtaz
    engtaz Posts: 7,669
    Lots of opinions on that topic. Carver, Adcom, Outlaw are fine amps. Depends on how much you want to spend. Outlaw has good amps. General consensuses is 200 to 250 @ 8 ohms wpc should about do it. The amps I mentioned have a good cost per watt value. These amps also support 4 ohm loads.
    Good Luck,
    engtaz
    engtaz
  • phuz
    phuz Posts: 2,372
    How big is your room? What exactly is your complaint in regards to the sound?
    IHF dynamic power on that amp is 390wpc @ 4ohms, and it's 2ohm stable. I don't think power is the issue, maybe you just don't like NAD's sound. Or maybe it's that receiver you're using as a pre.
    engtaz made good suggestions. Others to check out are Rotel, Parasound, Sunfire, B&K. Searching for something like "lsi amp" will get you tons of results.
  • G-2
    G-2 Posts: 533
    phuz and engtaz gave you some great amp manufactureres, Earthquake Cinenova Grande Series makes great HT amps. What are you lacking? These are all good amp company's...
    Chane
    A3rx-c's, A2rc-c, A1rx-c's|Miller & Kreisel V-125's|Sony XBR65X810C 65" 4K LED TV|
    Earthquake Cinenova Grande-5|Pioneer Elite - VSX-84TXSi-AVR|TRIPPLITE LCR2400|
    Ultrasonic Amp Stand|Blue Jeans,Audioquest,Monster Cables|
    2 - Channel
    Polk
    RTA 12c's w/RDO194 TWEETS, clarity ESA caps mills resistors (full mod)|Turntable|
    Anthem MCA 2|Acurus Act 3 Pre Pro|Parasound P/Ph 100|Pioneer Elite N-30|Adcom GDA600|
    Premier Rack|Blue Jeans,Audioquest,Monster Cables|
