Girlfriend's Dim Witted Dimmer Switch Idea
So Im pleased that I solved my buzzing problem last week (with the help of Club Polk members), it was an interconnect. No problems in sight, just sitting back and saving for the next upgrade .... seems like problems find people who are relaxing and have their guard down....
My girlfriend got this terrible idea that she wants a dimmer switch installed in the formal dining room which uses the same lines as my electronics. I put an end to such ideas ... saying "That wont happen as my electronics are sensitive to such things". The electrician was there and said that the noise would only happen when it is being turned ... that was enough... "No". So I leave for the gym and apparently she goes ahead and tells the electrician to come back tommorow and install the dimmer switch .... THAT WAS ENOUGH TO START A FIGHT! I told her unless she wanted to pay for a 800$ voltage stabilzer WE WERE NOT GETTING A DIMMER SWITCH ... she got all upset, telling me shes always wanted a dimmer switch for romantic dinners and setting the mood of a party. I wouldnt let down, saying my gear was worth thousands and didnt want a garbage dimmer switch damaging my gear for some guests I probably would rather not have there ...
Anyway, can anyone explain what a dimmer switch does to the electronics on the same line (damage? temporary noise?)... would a nice voltage stabilizer solve the problem with a dimmer switch. Im thinking a 20 amp dedicated line would be too expensive if you are hiring someone to do this. I read that EarlyBird got it for 180$ but sounds like you had a good deal on labor and helped out as well as bought your own equipment ... I am useless, dont know any electricians, so Im imagining wads of money to be spent on this ..
Thoughts would be appreciated ... I will not cave on this fight unless I can get a 20 amp dedicated line or a voltage stabilizer (if that would help?).
Thanks ahead of time.
Zsolt
Zsolt
Post edited by zx_toth on
The 20 amp dedicated line will cost less than it will take to get your girlfriend happy again Install the dimmer switch and see if it actually adds any noise to the circuit. The good ones don't add much interference, ie spend $25 or so on it. If there is noise, then a $250 power conditioner from Panamax is about the same cost as the nice dinner and night on the town you're out at this point.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
A dimmer actualy curves the voltage feild in lamins terme puts resistance on the electrical wire going to the dimmer.HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
... she got all upset, telling me shes always wanted a dimmer switch for romantic dinners and setting the mood of a party."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
A dimmer uses pulse width modulation to dim the light. Think of flipping a switch really fast. Flip it on for half of the time and off for the other half of the time and you have 50% duty cycle, a perfect square wave, and 50% of total power delivered. This does indeed create noise, but I'd imagine the circuit designer would put some capacitors in the circuit to account for this. When it is set to full brightness, the duty cycle should be 100% and it shouldn't create any noise. Any noise it does create will be very low in amplitude, and probably won't add much more noise to the line than already exists. Your gear has filters in power supplies to get rid of power line noise. I wouldn't worry about it too much, chances are you won't hear the difference.
Hmm ... the general impression Im getting is that the dimmer may or may not add a bit of interference. However this bit of noise which would occur only when it was in use would not cause any damage to componets, however not getting the dimer switch may damage the relationship ...
I may have to change my a-hole act tommorow morning to something more pleasant ...
Zsolt -
Get a dimmer switch and get a dedicated 20 amp line. Win win. Your stuff will sound better on the dedicated circuit. Get at least one.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Eating a little humble pie hasn't killed anyone as far as I know. A little mood lighting and a good marriage far out-weigh a few transients in an AC sine wave. Dimmer switch. IMHO
Zsolt
Romantic dinners and setting the mood. That's all good dud, you can't win this argument. So let her have the dimmer, see if it causes noise then let's see what options we can come up with.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
I threw a dimmer switch in my room to watch movies and so far so good. I didn't notice any added noise and when it comes to music the lights are either on or off all the way
Good luck with this one! BTW, you don't need an electrician to install a dimmer switch. It's not a big task as long as you make sure to shut off the power first. -
Go high quality or don't get one at all. $6 dimmers can be noisy, both physically and electrically.
From the Lutron website, RFI is the hum to be watched for.
WHAT IS RADIO FREQUENCY INTERFERENCE (RFI)?
RFI is a buzzing noise which may occur in some audio and radio equipment when solid-state dimmers are used nearby. Although every Lutron dimmer contains a filter to suppress RFI, additional filtering may be required in some applications. Typical examples of RFI-sensitive equipment are AM radios, stereo sound systems, broadcasting equipment, intercom systems, public address systems, and wireless telephones.
RFI can be transmitted in two ways:
Radiated
Conducted
Note: The suggestions in this application note will help minimize RFI: however, they do not guarantee that RFI will be completely eliminated.
Radiated RFI
Any sensitive equipment that is in close proximity to dimming equipment can pick up the RFI and generate noise into its system.
The following are three possible ways to minimize the radiated RFI:
Physically separate the RFI-sensitive equipment from the dimmer and its wiring.
Run dimmer wiring in its own metal conduit.
Use a lamp debuzzing coil (available from Lutron) to filter the RFI. See below for more information.
Conducted RFI
In some cases, RFI is conducted through the building wiring and directly into the AC power supply of the sensitive equipment.
To minimize the conducted RFI, follow these guidelines:
Feed sensitive equipment from a circuit without a dimmer on it.
Add a power-line filter to the sensitive equipment.
Add shielded wire for all microphones and input cables. Also, use low-impedance balanced microphone cables, which are less susceptible to interference than high-impedance types.
Make sure all the equipment is grounded. Connect all shields to the ground at one point. Ground lighting fixture metal housings properly.
Use a lamp debuzzing coil (available from Lutron) to filter the RFI.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Your either going to get noise from the dimmer switch or noise from your girl friend. So, there really are two solutions to this problem.
Right but at least he can turn the dimmer switch off.Be gentle, I'm new to all this...
The mind blowing speed of the BRAIN TRAIN... -
This is awsome... you didn't know exactly what makes a dimmer switch bad... but you still put your foot down and said NO to your girl's romantic desires... now this, my friends, is a true audiophile.
The girl will get over it... this is what they make candles for, as someone else already said. If she wants things dim so bad, why don't YOU surprise her with candle lit romance, and then let her know that romance cannot be just demanded, and dimmer switch or no, unless you both are happy with it, it isn't going to solve anything. She needs to know why it is so important to you, and you need to show her, that you want to compromise.
If it was me? I would just get a nice post modern lamp, put a low wattage bulb in it, and turn off the main lights and leave the lamp on for "dim" light. Dimmer switches aren't just noisy, they are tacky. -
You want the dedicated line. So she gets the switch, you get the power line and maybe something else from her.
RT1 -
Get her a dimmer...sheesh.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
You should get a 20 amp dedicated line for the dimmer...
That would solve everything- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I didn't see where you two are married. I say dump her now while you have the option and date someone more amenable to your idiosyncrasies.There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
This is not one you want to get too upset over.....besides, she may look better when the lights are low.B&W 804s mains
B&W HTM4 center
Polk PSW 1000 sub
Outlaw 990 Pre Amp
Anthem MCA 30 Amp
Monitor Radius 180 surrounds
Audiosource Stereo Amp for surrounds
Denon 2910 Universal DVD/SACD Player
Comcast DVR
Pioneer Elite 42" Plasma 940 HD
Harmony Universal Remote
Blue Jeans interconnects and biwires
Itunes Air Express -
I am telling you, get the dedicated line for thr rig. This little argument is a blessing in disguise. You will thank her.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
You should have back handed her and then escorted the electrician out by gunpoint.
EDIT: Emoticon added for the slow ones.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
is "in lamins terme" Latin perhaps? -
From the Islamic Guide to Relationships - admonish her 4 to 6 times a day, refuse to share her bed, then beat her lightly about the body leaving no marks. She should start coming around at that point
(and for the slow ones, I am joking :rolleyes:)DKG999
Problem solved on your end.
Same here, dimmer in the fam room. No prob. Installed it myself. -
Shes wearing a big rock that I bought for her, so the marraige thing is on the way and we just bought a house together .... so the dumping not so easy and wouldnt want to anyway
So many funny comments and good advice ...
Ill probably let her have her dimmer switch ... I dont mind an electrician doing it as she is paying. I will make sure it is a high quality dimmer and than also inquire about the cost of getting a 20 amp dedicated line though it isnt my first priority at this point for my rig ...
I know it is funny how I stomped my foot down without knowing what a dimmer switch did that was detrimental to the sound but I knew it was SOMEHOW detrimental and that was enough for me ... I did explain to her that it was detrimental to my equipment and for that reason did not approve of this. She didnt mention that the electrician was coming back tonight so I may have done enough to ward this idea off ... though I will soften my stance and suggest candles, as many Casanovas on here have suggested, and not mention the dimmer if she doesnt mention it If the 20 amp service is affordable to my current financial situation I may bring up the dimmer again:D
Zsolt -
wingnut4772 wrote: »I am telling you, get the dedicated line for thr rig. This little argument is a blessing in disguise. You will thank her.
Plus one
She gets her dimmer, and you get a dedicated to the panel 20 amp circuit. Win Win;)Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Glad you decided to get her the dimmer. 'Eff the electrician. You can very easily install it yourself.
Don't worry about a dedicated line. A good quality switch probably won't make an audible difference.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Think of the brownie points you'll get for doing it yourself too! Four wires - two positive, two negative and no modification necessary as the good majority of dimmers are a drop in replacement for a regular light switch. All you'll probably need is a phillips screwdriver and maybe some wire cutters.
Put the stupid switch in yourself, it's a 20 min job at the worst. And if you do it, one you save money, (think cables or cd's/dvd's), and you rack up valuble brownie pts with the SO.My equipment sig felt inadequate and deleted itself. -
Yeah!I'm a girl and I put in my own Lutron dimmer.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
