polk lsi 15 vs paradigm 60's v.4
now i realize this is a polk forum. but just wondering if anyone has compared the two speakers. the polks (on sales at jr) with an amp and no amp for the 60's. any thoughts would be appreciated.
lsi 15's, lsi c, lsi f/x
onkyo 805
sunfire tga 5200
toshiba - xa2
panasonic bd30
sony kdl40v2500
svs sb12+
onkyo 805
sunfire tga 5200
toshiba - xa2
panasonic bd30
sony kdl40v2500
svs sb12+
Post edited by margate21 on
Lsi are better for music. Good amplification is a must.
The studio 60's are easier to drive with HT receiver.
Bit on the bright side. I have a set of studio 60's v2 running
in my 2 channel with a tube amp. Tubes really bring out their good side.
I would just get the 40's and get a good sub with the extra money.
How will they be used? Mostly music or HT?"The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
sucks2beme wrote: »Lsi are better for music. Good amplification is a must.
they will be used 70%ht/30%music. yes i am planning on getting a sub. i like towers better than book shelves on stands. what is the diff btw tube and power amps.Home Theater
onkyo 805
sunfire tga 5200
toshiba - xa2
panasonic bd30
sony kdl40v2500
svs sb12+ -
Tubes give a different, warmer sound than solid state.
For 5 or 7.1, not practical, too costly, too much maintenance.
If you go for an LSI setup, better plan on a HT receiver with preamp outputs
and separate amps. Even with the Paradigms, better go big or stay home on the HT unit you use. Do a search on this website, and you'll find plenty of info.
The biggest problem most people have is most HT receivers are waaaay
overrated on their power specs."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
sucks2beme wrote: »Tubes give a different, warmer sound than solid state.
is the adcom 7705 or the rotel 1095 powerful enough. i have been looking at outlaw, parasound, arcam, emotiva, carver, sunfire and others that everyone has mentioned. but my problem is the depth in my entertainment center. i would prefer not to cut another hole in the back of the entertaiment center :eek: ( i already did so to fit my onkyo 805). a painful process.Home Theater
onkyo 805
sunfire tga 5200
toshiba - xa2
panasonic bd30
sony kdl40v2500
svs sb12+ -
I have a B&K. Their newer models (anything built late 90's to today) have internal heat sinks, and they are pretty short depth-wise.
Carvers also are pretty short depth-wise.
I would check out some B&K stereo amps on Audiogon for those Lsi15s. Maybe the 200.2 or 2200, or 2240, or something.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
sucks2beme wrote: »...If you go for an LSi setup, better plan on a HT receiver with preamp outputs and separate amps. Even with the Paradigms, better go big or stay home on the HT unit you use. Do a search on this website, and you'll find plenty of info. The biggest problem most people have is most HT receivers are waaaay overrated on their power specs.
+1000 - If you're going LSi you need to be factoring additional amps into your equation. Adcom, Rotel, outlaw, parasound, arcam, emotiva, carver, sunfire, whatever; (our view) high current power (200wpc or more) is what the LSi's like. It also sounds from your comment that you've got your gear (stack) in an 'enclosed' type of case; we'd urge you to be sure there is plenty of available air for circulation (if there is disregard the following). Onkyo AVR's get pretty warm when they're on/taxed, and the same will probably be true of amps you may add. Just our $.02. Good luck with your setup, and most importantly; enjoy yourself!Home Theater
Chane A3rx-c's, A2rc-c, A1rx-c's|Miller & Kreisel V-125's|Sony XBR65X810C 65" 4K LED TV|
Earthquake Cinenova Grande-5|Pioneer Elite - VSX-84TXSi-AVR|TRIPPLITE LCR2400|
Ultrasonic Amp Stand|Blue Jeans,Audioquest,Monster Cables|
2 - Channel
Polk RTA 12c's w/RDO194 TWEETS, clarity ESA caps mills resistors (full mod)|Turntable|
Anthem MCA 2|Acurus Act 3 Pre Pro|Parasound P/Ph 100|Pioneer Elite N-30|Adcom GDA600|
Premier Rack|Blue Jeans,Audioquest,Monster Cables| -
I have to agree with most everything said on this thread, except the high power. The Lsi's require quality power, 200 wpc don't mean squat. Give me a quality 40 wpc tube amp, or a quality 75watt SS amp and they will drive the Lsi's just fine.
However, since you're going with 70% HT, you might find the P-dimes a better fit and the Studio 40's and and HSU or SVS sub would be a fine match.Review Site_ (((AudioPursuit)))
Former Staff Member TONEAudio
2 Ch. System
Cable/Wires: Cardas, AudioArt, Shunyata Venom 3 -
thanks for your thoughts. yes i know the 805 runs hot. i bought 3 fans to place in my e/c. i left about 6" for height and the hole i cut in the back seems to be working. the a/v has yet to get hot to the touch (lucky me compared to what i have read).
I will check out the carvers and the b&k's.Home Theater
onkyo 805
sunfire tga 5200
toshiba - xa2
panasonic bd30
sony kdl40v2500
svs sb12+ -
I currently have my LSi15's on a Carver TFM 45 (same as the TFM 42 and m4.0t) either of those will make the LSi's sing pretty nice.Living Room 2 Channel -
Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
Upstairs 2 Channel Rig -
Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
