Why no love for LSi25's?
hockeyboy
hockeyboy Posts: 1,428
edited April 2007 in Speakers
I demo'd 15's and 25's side by side for over an hour. Hands down, IMO the 25s were dramatically better than the 15's.
Why is there no love for the 25s when it seems to be the flagship speaker for Polk?:eek:
My Main Gear
Mitsu HC5000 (Proj.)
Marantz SR8001 (AVR)
Sunfire TGA7200 (AMP)
Marantz DV7001 (SACD)
Samsung BD-P1500 Blu-Ray
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
DUAL SVS 20-39 CS Plus
(Passive Subs)
Marantz IS201 I-Pod Dock[/SIZE]
Panamax M5300EX
Carada Criterion 106" Brightwhite Screen
Sunfire TGA 5200 & (4) B&W 605's in the party room
Post edited by hockeyboy on
  • venomclan
    venomclan Posts: 2,467
    edited March 2007
    I find that a lot of audiophiles prefer passive speakers in general. Outboard amps seem to outperform active speaker amps a lot of the time, and you do not need to plug in your speakers. Another reason is that many also use subwoofers with their towers, which also hit harder than active speakers anyway. IMHO
    V
    heiney9 Posts: 25,432
    edited March 2007
    I prefer to power my speakers with my own amplification. Plain and simple. The LSi 25 is a great speaker.
  • Gaara
    Gaara Posts: 2,415
    edited March 2007
    I would imagine it would also be because of the price. At $1000 more then the 15s you don't seem to gain a whole lot...powered woofers that don't go deep enough. Paying an extra $1000 to make a speaker full range makes sense for some, but the LSi25s aren't full range. You would still need a sub to go deep, which kinda defeats the purpose of spending the extra $1000.
    I would also think that it would be difficult for some to plug them in. It makes things all the more complicated to have to run the power cords out of them, and run interconnects to them, on top of the standard speaker wire.
    Plus once you start getting close to the $3000 range theres better out there for the money. I for one would much rather go with a pair of 9s or 15s with a good quality sub then 25s.
    Jared
  • ND13
    ND13 Posts: 7,601
    edited March 2007
    I'm not much in favor of using powered towers, either. Give me 9s with a good sub, too.
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • ben62670
    ben62670 Posts: 15,969
    edited March 2007
    Exactly
    Ben
  • engtaz
    engtaz Posts: 7,669
    edited April 2007
    I second that!!:)
    engtaz
    engtaz
  • kaisersose
    kaisersose Posts: 92
    edited April 2007
    So are you guys saying you would pick 9's over a 15?
  • marker
    marker Posts: 1,084
    edited April 2007
    As far as the 15s vs the 25s, I personally would pick the 25s for two reasons
    1- a sweet little integrated amp would be more than enough for the top end on them since they power their own bass (thus leveling the playing field somewhat on the price difference considering the 15s need a lot more power)
    and
    2- I'd rather have more control over their bass than just placement. You can dial the 25s in as to how you think they sound best, whereas the 15s limit you to trying to adjust them via macro and micro positioning in the room.
  • VXR8
    VXR8 Posts: 291
    edited April 2007
    I'd be interested in the same as I'd consider the 25s and / or the 15s, but if you think the 9s are sufficient with good separate amplification and a sub, I too may go down this path with the 9s.
    Thanks in advance.
    Regards - Gaz from the land of Oz
    Main System
    Denon - AVC-4700H
    Emotiva - XPA-9
    Cambridge Audio - Azur 851C - CXUHD
    Polk Audio - Legend L800 - Legend L400 - Legend L900 - LSiM fx - OWM3
    SVS - PB1000 x 2
    Foxtel - iQ4
    Belkin - Pure AV PF40
    Sony K77A9G
    Front Room System
    PS Audio - Sprout 100
    Cambridge Audio - CXC S2 - CA752BD
    Sony - UBX800 4K BluRay
    Polk Audio - Legend L200
  • hockeyboy
    edited April 2007
    So if I am understanding the group, the feeling is that the 15's under proper amplification (I am using a Sunfire 7200 and Marantz SR8001) will give better result than the 25's up front?
    For me the difference will be about 6oo dollars for the pair.
    My Main Gear
    LSi 15's (Front)
    LSiC (Center)
    LSiFx (Surrounds)
    (Passive Subs)
    Panamax M5300EX
  • ben62670
    edited April 2007
    I would go 9's, and take the extra coin, and get an SVS sub.
    Ben
  • TN_Polk_Lover
    TN_Polk_Lover Posts: 243
    edited April 2007
    The best speaker placement for imaging, soundstage, etc. may not be the best placement for the lowest frequencies. If you are buying the 25's to get better low frequencies, then the placement can be problematic.
    If you buy the 15's for just a good all around speaker, but aren't trying to reach the lowest octave, then you can place them for best imaging, and let the lowest frequencies fall where they may. If you just want good music, but don't listen to pipe organ music, then these are probably your all around best choice.
    If you do want to play the very lowest octave and/or want thunderous sound effects from movies AND you still want good control over imaging / soundstage, then the LSi9 / subwoofer combination is probably the way to go.
    Robert
    You are officially in the high-end of the deep-end of the top-end.
    Bonus Room Over Garage:
    Toshiba 27" CRT TV
    Digital Source: Sony DVP-NS3100ES
    DVR: Panasonic DMR-ES15
    Denon 3806 AV Receiver
    - L/R Preamp out to Parasound HCA-1200 Amp
    Polk RTi70's, CSi40 Center, RTi38 Side Surrounds, RTi38 Back Surrounds
    Living Room: (2ch only)
    TV: Sony KV20-FV12
    DVD Player: Sony DVP-NS715P
    Yamaha R9 Receiver Polk RTi38's
  • xsmi
    xsmi Posts: 1,801
    edited April 2007
    I like the 25's better because i would use them only for HT and I have a small room so floorspace is at a premium. If I do music, i want a passive speaker and NO sub at all.
    2-channelBelles 22A Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • Holydoc
    Holydoc Posts: 1,048
    edited April 2007
    Could you expand on this statement? Why wouldn't an LSi15 / subwoofer combination be better?
    I can understand the problems with the LSi25 powered woofers as opposed to the unpowered LSi15. But I do not quite understand yet why anyone would recommend the LSi9 over the LSi15. Isn't the LSi15 just an LSi9 with an 8" woofer added below the box acting like a stand? I know that Driver 1 is a bit different as far as crossover settings but that is to allow the woofer of the LSi15 to catch most of the lows. Maybe I am totally off base here, but it would appear to me that the LSi15 gives you the most flexibility of placement and combinations.
    Of course I am just typing to pass the time. After all, I own the RTi series and thus have NO dog in this fight. :o
    Holydoc (Home Theatre Lover)
    __________________________________________
    Panasonic -50PX600U 50" Plasma
    Onkyo -TX-NR901 Receiver
    Oppo -Oppo 980HD Universal DVD Player
    Outlaw -770 (7x200watt) Amplifier
    PolkAudio - RTi12 (Left and Right)
    PolkAudio - CSi5 (Center)
    PolkAudio - FXi3 (Back and Surround)
    SVS - PB-12/Plus (Subwoofer)
    Bluejean Cables - Interconnects
    Logitech Harmony 880 - Remote
    VR3 Posts: 29,428
    edited April 2007
    My vote is for the LSi13
    Its a LSi15 without subwoofer. Its a shame it does not exist.
    The LSi9 has insane amounts of bass. If they would harvest that trait into a tower and extend it to 35hz or so and get rid of the punchiness in the mids - would have a stellar speaker on our hands!
  • TN_Polk_Lover
    edited April 2007
    Holydoc wrote: »
    Well, first let me qualify that I don't yet own a subwoofer, so what I'm saying is really just based on what I've read or heard other people say, plus just a little of my own opinion. I have had experience with positioning tower speakers (RTi70's) and smaller speakers on stands (RTi38's), plus some other older non-polks that I used to have.
    Yes, LSi15's with a subwoofer would certainly be a good combination. You could have the subwoofer crossover fairly low, since the LSi15's will play pretty low all on their own. I would think that if you were definitely planning on having a subwoofer (or subwoofers), then it would be cheaper to go with the LSi9's. Plus, sometimes a smaller speaker (LSi9) will often image better than a tower speaker. I'm not really sure why this is, except maybe there is less surface area around the "plane" of the tweeter. Although I like my RTi70s because they have lower bass, my RTi38's image better. At times the RTi38's almost sound magical -- the image floats out in space between them and the speakers seem to disappear.
    Of course, your mileage may vary!
    Robert
    Toshiba 27" CRT TV
    TV: Sony KV20-FV12
  • hockeyboy
    edited April 2007
    Okay Ben. I started emailing SVS and that guy Ed over there really knows his business. He's a helluva salesman at any rate. I had a couple of extra channels open on my Sunfire 7200 so he talked me into dropping a grand onto a pair of 2039CSPlus (gave me a little discount). I clearly have the bass covered.
    This of course trimmed my budget for speakers. I have 400 watts per channel and am planning on FXi's in the back for my 5 channel. I will stay with my B&W60 for center for now. It is down to 15's or 9's for the front. Please help with some more opinions based on experience guys. Basically my whole system is being built on guidance from the Polk forum!
    My Main Gear
    LSi 15's (Front)
    LSiC (Center)
    LSiFx (Surrounds)
    (Passive Subs)
    Panamax M5300EX
  • ben62670
    edited April 2007
    I would get the 9's. Its a lot more coin to get the 15's, and you allready have the bass covered. Don't let the size fool you. The 9's are very capable speakers.
    Ben
  • Ron Temple
    Ron Temple Posts: 3,212
    edited April 2007
    hockeyboy wrote: »
    Great deal...Ed sometimes drops by here and he definitely knows his stuff. ;)
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • venomclan
    edited April 2007
    hockeyboy wrote: »
    Ed's great, ask him if he still has the Outlaws I sold him a few years ago. :)
    V
  • hockeyboy
    edited April 2007
    I asked Ed what he recommended the same time I posed the question to the group and he responded today:
    I like the LSi-15s up front at this point - you get an 8" woofer internally XO'd at 150 Hz from what is essentially an LSi-9 up top. The 8" woofer will work very well down to 80 Hz, providing much more upper bass percussive impact than will the LSi-9 alone.
    My Main Gear
    LSi 15's (Front)
    LSiC (Center)
    LSiFx (Surrounds)
    (Passive Subs)
    Panamax M5300EX
