Help selecting AMP for Polk LSi's - budget around $500.
Nostalgic
Nostalgic Posts: 42
edited March 2007 in Electronics
Hey all.
I have a pair of LSi15's, an LSiC, and a crap psw100 sub coming. (I'm obviously replacing that sub soon enough). Use will be 80/20 for HT/music.
Anyway, I have an HK 435 receiver that is said to be pretty powerful for an AVR.
But, I do want to get the full potential out of my setup as well as prevent any damage to the speakers/AVR from powering their 4 ohm impedance with an AVR rated at 8 ohms.
Also, I will eventually add some surrounds so I'll have a 5.1 system.
Questions:
1)With a budget of about $500 (give or take a little), what would you recommend for an amp? I think I want at least 200 wpc into 4 ohms from what people are saying but who know. What amp do you recommend?
2)I have a separate cable for my future SVS or HSU amp and will use it from the sub out on my AVR. Do people use amps for their subs too or does the sub itself have it's own capable amp?
3) Will the amp you recommended in the $500 range be enough to make my LSi setup sing or will they not be near their potential with that budget?
Thanks everyone! I'm hoping to get it soon since my speakers will be here tomorrow.
N.
Post edited by Nostalgic on
  • dane_peterson
    dane_peterson Posts: 1,903
    edited February 2007
    1) For $500, you're not going to find a whole lot if you're looking for it to drive 5 channels. You might be able to find some 3-channel amps for that price... one name that comes to mind would be Adcom (GFA-5503).
    2) If your subwoofer has a built-in amplifier (also known as active subwoofers), there would be no need for separate amplifier. You would simply run the sub pre-out.
    3) The LSis will sound good. But they will sound BETTER once you get more power. The LSis are a power-hungry line of speakers.
    My suggestion, sell the subwoofer and put that money towards a quality amplifier. If your goals are to run 200watts at 8ohms, don't skimp out now. The downtime up front goes by a lot quicker than the downtime halfway down the road when you're already knee-deep in this stuff. Truthfully, it's tough to get enough power for a 5.1 LSi setup with $500... in fact, it's darn near impossible. $750 maybe...
  • cfrizz
    cfrizz Posts: 13,415
    Welcome Nostalgic. You should be looking at getting 200wpc @ 8ohms which will give you 300 @ 4. The more headroom you have the better.
    If you are planning a 5.1 system with all LSI's you should get a 5 channel 200wpc amp, & you won't find any at $500.
    So just take your time, save much more money & start looking at the used offerings for multichannel amps on Audiogon so that you can get a rough idea of what they are going for.
  • gwh
    gwh Posts: 1,451
    I've got 9's, 7's,& C running off a Parasound HCA-855A (discontinued) 125w@4 Ohm x 5.
    Works fine for me and the price was about half your budget(used off Ebay).
    G
    HT:
    Martin Logan Motion 40
    Martin Logan Motion 50XT
    Emotiva Airmotiv E2
    SVS SB16 Ultra
    Def Tech Reference Sub
    Yamaha RX-A3070
    Signal Cable speaker wires & interconnects.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    You could use a Parasound Halo A23 which is rated for 2x 125w @ 8 ohm, 2 x 200w @ 4 ohm. A sweet sounding amp which I think is a plus for LSi speakers.
    You could find one used on Gon for around $500.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • unc2701
    unc2701 Posts: 3,587
    Hell, get an Adcom 555 for the 15's and leave the LSiC on the HK. It should be fine pushing just the center, especially if you set it to small. Save up for a more serious 5 channel amp or just keep on adding 555's. Three Adcoms will have two power supplies more (and one channel more) than your typical 5x 200 amp and you can do a lot worse.
    Backburner:Krell KAV-300i
  • louthewiz
    louthewiz Posts: 581
    Emotiva is having a sale on 7 channel amps for 500 clams with free shipping ,
    Here is the link.
    http://www.emotiva.com/lpa1.html
    My gear,
    Acer PH530 720P PJ
    100 inch Da-Lite Video Spectra screen
    Yamaha HTR 5790
    Toshiba HD-A3
    Denon 1600 dvd player with sdi out,
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    1 Audiosource amp300 150 wpc Fronts
    1 Audiosource ampone bridged 200 watts powering center
    1 Onkyo M-282 105 wpc amplifier sides
    polk cs400 center
    polk RT400 mains
    Polk mkII back surrounds,
    Polk FX300fxi dipole surrounds
    Velodyne DPS-10 sub
    Klipsch KSW-10 sub.:cool:
  • Nostalgic
    Nostalgic Posts: 42
    I was really interested in the lpa-1. However, I have read posts by several people stating that the lpa-1 will not offer much if any difference than my HK 435 AVR.
    Any thoughts?
  • louthewiz
    I highly doubt it ,that amp has real balls and plenty of power to spare for the price and I can guarentee you that it has plenty of juice for your speakers and it won't wimp out like the H/K will.
    My gear,
    Acer PH530 720P PJ
    Yamaha HTR 5790
    Toshiba HD-A3
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    polk cs400 center
    polk RT400 mains
    Velodyne DPS-10 sub
  • Ron Temple
    Ron Temple Posts: 3,212
    Any thoughts?
    try it...
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • Nostalgic
    Nostalgic Posts: 42
    Ron Temple wrote:
    try it...
    I know that's the best way. But, the free trial may not include shipping this beast back to them. Just want some more insight from you experienced guys. :)
  • dane_peterson
    For $500, you can't really go wrong. I'm with Ron and Lou, give it a try.
  • cfrizz
    edited March 2007
    This is the most important thing that you have pointed out!
    It's easy for these guys to say try it, they won't be out the shipping costs or have the aggravation of having to return it if you are not satisfied! Then the additional expense & aggravation of getting what you should have gotten the first time around!
    I'm a firm believer in doing it right the first time Nostalgic. It is much better to have more than you need, rather than find out the hard way that you should have gotten more after the fact.
    You won't have to doubt having more power, which can be used through all future upgrades over the years.
    Unless you are one of those people who like to endlessly try new gear just to see the difference it makes, do yourself a favor & go for the gold the first time around.:)
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited March 2007
    Pick up an Aragon 2004 for the 15's and thank me later.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited March 2007
    I counted 268 amps I thought would work for you, then my boss said I have to quit wasting my time, I told him this is not wasting time, it's important, it is audio, it is passion, he disagreed.
    OK, buy something with high current, I suggest paying more than you can really afford, you will be happier in the end. Broke but happier and misery does love company.
    RT1
    Edit: OOOOOoooooo, Russ that is a great idea, I should get an Aragon, great amp, so then I will have an A-Aragon and B-Balanced Audio, how about C, what should I get for C, man I will end up with 26 amps this way, effin awesome idea, the Alphabet Rig is Born. I am gong to need a bigger Shed. Christ just realized I already have two B's--B&K and Balanced Audio, should I get another A so I am balanced, naw........it will be like baseball cards just have doubles of some.
  • disneyjoe7
    edited March 2007
    Ted, reach for the Decaf next time ;)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    edited March 2007
    Ted...
    If that stupid letter "Y" can't even figure out whether it's a consonant or a vowel, how the hell do you expect it to maintain the integrity of a pure signal.
    Garbage in, garbage out
  • mldennison
    mldennison Posts: 307
    edited March 2007
    just to offer a different perspective...
    i dont think much of putting alot of effort into the rear channels, even for HT. concentrate on getting a nice 2/3 channel amp (lots of good recommendations above) for your front and center speakers and use the HK for the rears. that should allow you to get something very nice for the front soundstage and still stay within your budget. again, this is just my opinion...
  • ben62670
    ben62670 Posts: 15,969
    edited March 2007
    You can get Adcom GFA-555's all the time for $350 off ebay. There are about 12 on there right now. I have one and it puts out 200@8ohms, and 325@4ohms.
    kinda a no brainer if you ask me.
    Ben
  • McLoki
    McLoki Posts: 5,231
    edited March 2007
    Ted...
    "Y" get a nice Yamaha amp. Maybe something mid-80's for your sda's (like an M-85)
    Ted "C" - Carey Audio they should have at least a few amps that sound decent... :)
    The alphabet rig, sounds like a killer Idea for polkfest.
    Michael
  • disneyjoe7
    edited March 2007
    H for Halo
    P for Parasound
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Sami
    Sami Posts: 4,634
    edited March 2007
    I was going to say the same. Got one from Russ and it's a great match for my 15's.
  • RuSsMaN
    edited March 2007
    Y is for YBA.
    Yamaha, that's funny!
  • reeltrouble1
    edited March 2007
    ooohhhhhhhhh, I likey YBA, nice, unique, good looking stuff, I could work backwards from Z........man this is going to cost big big bucks, I may have to pan-handle in front of Winn-Dixie with my monkey.....
    let me see a Z, not an easy one, Zu makes some nice speakers, don't know about amps....
    sorry for the highjack but these amps being thrown around are ones you might consider, well, at least know about as the budget may not allow.
  • PSOVLSK
    PSOVLSK Posts: 5,235
    edited March 2007
    My system is similar to what unc2701 suggested. I'm running my Lsi7's off of an Adcom 545 and the rest of my system off of my H/K7300. For me, I don't notice a difference good or bad in the sound, but my AVR runs much cooler now. I'm not offering this up as saying it's the way you should go, just thought I'd concur that this is an option for you. On that note, I think you'd probably want the Adcom 555 that unc mentioned...don't think you'd be satisfied powering the LSi15's with the 545.
  • disneyjoe7
    edited March 2007
    Well I run Halo A23 amps for my L / R with my Onk driving the center and rear surrounds. I can say I noticed a difference :D night to day, day to Halo, night to Onk.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • polka boy
    polka boy Posts: 13
    edited March 2007
    Look for a used Rotel 1075, audiogon.com and specs at the Rotel website. You can get one used for ~$700 in grat condition.
  • polka boy
    polka boy Posts: 13
    edited March 2007
    I checked audiogon.com and the few Rotel 1075's they have are sold. It is 120 W x 5 channels at 8 ohms. Or get big brother the 1095 at 200 W x 5 at 8 ohms. This will cost you more like $1,000 to $1,200 used.
  • josh_parsons626
    josh_parsons626 Posts: 219
    edited March 2007
    Hey here's a question.....alright we already know an Adcom is a damn good cheap amp. What about a damn good cheap pre/pro? What would be some suggestions? And while I'm asking questions is it better to use your DVD player to listen to CD's or a dedicated CD player?
    Don't forget to look at My Home Theater :D
    Receiver - Onkyo TX-SR503
    Fronts - Polk Audio Monitor 40
    Center - Polk Audio CS1
    Surrounds - Paradigm Cinema ADP
    Subwoofer - Velodyne VRP-1200
