Center Speaker with In-wall RC65i's?
Any suggestions? Will it sound okay if I get another RC65i as my center? It doesn't seem like a true center speaker though? I am going for a "clean" look, so using a non-inwall speaker isn't something I would like to do.
Post edited by drm31078 on
RC265i is a commonly accepted option. I would think the RC65i would work as well."People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf." George Orwell
shawn birch wrote:RC265i is a commonly accepted option. I would think the RC65i would work as well.
I think you mean the TC265i, right? -
Can I use a TC series with an RC series? Does it matter if the TC265i is mounted vertical instead of horizontal? I don't think I have enough room between studs to mount it horizontal.
DaveMuell wrote:I think you mean the TC265i, right?
GOODNESS, I meant TC265i and TC65i. SOrry to confuse you! I think the TC is leaps and bounds better than the RC. Sorry!"People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf." George Orwell -
The TC is also much more expensive. My budget is keeping me to the RC series, therefore should I just use another RC65 or RC85 for the center then?
Dave, I got your PM...don't have enough posts to respond back...might be interested
need more posts...sorry guys
3 more times...
2 more...
1 more!!!!!
I got your PM and replied.
Are you using the RC series for the front mains? If that is the case you should go with another RC model as to timbre match the front stage...
