monitor 70's
what do you guys think of the monitor 70's?
John Tyler Birch
home audio system:
Denon avr-1907
Sony dvd/cd changer 5 disc
nakamichi BX-100 tape deck
2 Polk Audio monitor 70's
Velodyne DPS-12 subwoofer
RCA TV
NAK 600 tape deck
Monster power line conditioning power center
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
Post edited by 98thumpin on
Love mine, great for music no question...Rockin' In My House
Pioneer 50 inch Plasma TV
Denon AVR-3806
Denon DVD-1930ci
Polk Montor 70's
Polk PSW-12
Polk CS2
Polk Monitor 40's
Sirius Satellite Radio, Monster 3500MKII -
how do they compare to the higher end polksJohn Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
Monster power line conditioning power center -
I am afraid I don't have the resources in my area to be able to compare much, I can say that stack up very well with speakers in the same price range. Not many Polk shops around here...Rockin' In My House
Denon AVR-3806
Denon DVD-1930ci
Polk Montor 70's
Polk PSW-12
Polk CS2
Polk Monitor 40's
I had the Monitor 70's for 2 years and I can say for their price range they kick ****. They have a full presence and fill-up the room nicely. They are great for music. I upgraded to Rti10's because I found the 70's to lack some detail and clarity. I also found the bass to be a bit muddy and bloated. At first the Rti10, seemed too bright for me, but after I got over the initial shock, I'm finding that I enjoy them much more. The Rti line is a significant jump from the monitor line. Music is very clear, crisp and detailed. The bass is less distorted and goes lower. The monitor series is a good entry level speaker- if you can afford it, go with the Rti's.
If you can find a good price on them, I think they're definitely worth a look, but I guess overall it depends how much of a budget you have to play with. Overall, I think they have a great balanced sound and they do fill out a room nicely, as Ern said. I use them for music and movies and I think they work for both quite nicely.
If I were to start over now, I would probably look more into the RTi10s or RTi12s after having listened to them a lot recently, while looking for a new center. They have a much brighter sound which contrasts a lot against the warmer sound of the monitors, but I think they does a better job on the overall soundscape. But if you can find a showroom, you should just see what sounds best to you.
But as far as the Monitor 70s go, I still use them, I still love them, and I don't regret owning them one bit. -
thanks for the informationJohn Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
