R30's w/ Paradigm Center
edited August 2006 in Speakers
I just changed a pair of old Infinity sm 125 to a pair of R-30's for my fronts. My current 5.1 set-up is:
Polk R-30 (mains)
Polk R-15 (surrounds)
Paradigm cc-170 (center)
Polk PSW303 (sub)
powered by Denon AVR 1804 (90wpc)
I know my sub is a little more than the recommended, but how about the center? I am thinking of possibly switching the center to a CS1, CS2, or CSi25.
I still can't quite figure out which of these centers would be ideal. Right now, these are the prices I can get for the following (Brand New on Ebay).
CSi25 - $83
CS1 - $113
CS2 - $203
Value-wise CSi25 would seem the best, considering the MSRP. I'm leaning towards the cheaper option of the CSi25 or CS1. Also, my Paradigm center sounds pretty good now, so I'm not sure a change is necessary. But, I know that in most systems, the fronts should match the center for same front soundstage qualities and properties.
I would probably sell the Paradigm, which would offset the cost. I'm not an audiophile, but a casual enthusiast. It sounds fine now, but I'm wondering if the matching of the center, would even sweeten the sound more. My living room is ~375 sq. feet. I may upgrade later on a bigger scale, and move this setup into my bedroom, so i'm unsure whether i should splurge now on a small upgrade, versus waiting and using the money for a bigger and badder setup in the future for the living room. I'm not going to go nuts about my bedroom setup.
Any thoughts?
Fronts: Monitor 60
Rears: Polk R-15
Center: Polk CS1
Sub: Polk PSW303
AVR: Denon AVR 1804
TV: 43" Samsung DLP
Post edited by sidespin on
Welcome!
    edited August 2006
    Yes, definately timbre match the center with the L/R. If you're not REAL big on the sound then you'd probably get away with the csi25 but if it was me i'd get the cs2 and upgrade all around to the monitor series (at least), because that's what i got right now and i think for entry level it sounds pretty good.
    Don't forget to look at My Home Theater :D
    Receiver - Onkyo TX-SR503
    Fronts - Polk Audio Monitor 40
    Center - Polk Audio CS1
    Surrounds - Paradigm Cinema ADP
    Subwoofer - Velodyne VRP-1200
    edited August 2006
    The CSi25 is a better match sonically and aesthetically to your current R series speakers.
    5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
    2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
    2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
    2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
    Kitchen: Sonos Play5.
    edited August 2006
    All of those centers mentioned are good. Add the CSi3 to your list as well; I use it with my rig. It sounds great, but you should audition for your own taste.
    Party on!
    _________________________
    Main: Polk R50s
    Center: Polk CSi3
    Surround: Polk R30s
    Rear: Polk R15s
    Sub: Polk PSW12
    Cherry Wood Edition
    Whirlwind Cables/Connectors
    Harman/Kardon AVR635
    Harman/Kardon DVD 27
    Sony RDR-GX300 DVDR
    Sony Bravia 40" XBR1
    edited August 2006
    Party on!
    I am running a Csi3 with my R30s and they match well. The center does run a little hotter than the R30s so I usually calibrate the center 1db less than the 30s. Other than that, they sound well.
    Receiver: harmankardon AVR235
    Mains: polk R30
    Center: polk CSi3
    Rear Surrounds: polk R20
    Subwoofer: polk PSW404
    DVD: Panasonic DVD-S29
    edited August 2006
    You shouldn't cheap out on center speakers. Buy the best you can. Even though different lines from Polk use different tweeters, I find that they sound quite similar and pretty difficult to tell apart when watching movies. I had the CSi40 and RT800i's at one time and it sounded fine.
    edited August 2006
    Thanks for replies. Now I'm deciding between the CS2 or CSi3. The CSi3 gives me slight upgrade capability for later, but I plan on using the same center for this setup with the R-30's & R-15's, as it would maybe move to my bedroom. The upgrade/perfection bug has bitten me. I'm thinking of getting a CS2 to complete this system. Then when the monster upgrade bug hits me, I could then deal with it then. But, changing the center to match my current setup would be good. What about a seperate amp for the mains? My Denon AVR-1804 runs @ 90 Watts per Channel. I've heard that those power specs could be a bit on the exaggerated side, so maybe i could use more power for these speakers. R-30 are supposed to run @ 20-150 watts per channel. Would amping these be useless, as it doesn't need that kind of power?
    I think I am looking for a nice decent solution in perfecting and slightly upgrading what I have currently. I believe a new center will help. A seperate amp also, or unneccessary?
    Fronts: Monitor 60
    Rears: Polk R-15
    Center: Polk CS1
    Sub: Polk PSW303
    AVR: Denon AVR 1804
    TV: 43" Samsung DLP
Welcome!
Welcome!
