got the cardas RCA's on the 535
nadams
nadams Posts: 5,877
edited August 2006 in Electronics
I just haven't had time to do it, but I went ahead and got 'er did tonight...
I'm still at a loss as how to best upgrade the speaker terminals to nicer binding posts....
Ludicrous gibs!
Post edited by nadams on
    F1nut Posts: 51,783
    edited August 2006
    Looks good, Noah. Are the binding posts board mounted?
  • nadams
    nadams Posts: 5,877
    edited August 2006
    Yeah, they're soldered directly to the board that has the 4 big caps on it.
    Ludicrous gibs!
    F1nut Posts: 51,783
    edited August 2006
    Ok, you'll have to run wire from the points on the board to the new posts. Just determine what gauge wire will fit into the holes, order some along with the posts and you're set.
    If that doesn't make sense, I'll try again.:)
  • nadams
    nadams Posts: 5,877
    edited August 2006
    makes sense... sounds like a lot of work
    at this point, the stock connections are working fine. I only replaced the RCA's because the originals had a sleeve missing.
    Ludicrous gibs!
    F1nut Posts: 51,783
    edited August 2006
    I can't tell from the above pics, but you should be able to remove the ps board, which should make for an easy upgrade job.
    BTW, you can just remove the second set (B) of posts and get some plastic plugs to fill in the holes.
