can RTi12's handle 400w
my other adcom GFA555 is do to be here tomorrow and im going to mono each one to my 12's....can they really handle all that power? the top end of my 12's is running off my reciever and i cant imagine it getting any louder....i dont wanna blow my speakers or burn up the tweeter....REALLY, can they handle all that power???? anyone else really pushing there 12's hard and have any experience doing it??
Yamaha RX-V2600
Adcom GFA555 x 2
Yamaha CD685 cd changer
Yamaha Dvd c950 dvd changer
Polk RTi12 mains
Polk CSi3 center
Polk psw303
Polk RTi6 (surround and surround back)
Acoustic Research 12in 200 watt sub(8 years old and still hits hard:D)
WindyWillys cooling fan (works great)
Mitsubishi 52in big screen
blue jeans cables
AR interconnects
Adcom GFA555 x 2
Polk RTi12 mains
Polk CSi3 center
Polk psw303
blue jeans cables
AR interconnects
Post edited by ronnie on
No experience at all here, but have you considered bi-amping with the two amps instead of putting them into mono mode? I don't *know* which is better, but when you put them into mono mode, that'll in effect make them be pushing a speaker of lower resistance, thus requiring more current from them and lowering your headroom.
I don't *know* that it'd be better, but I'd at least look into bi-amping with the pair instead of putting them in mono mode.
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
for a $1,500 RTi moniker and 6 drivers per enclosure, they better be able to handle 400 watts. They better be able to handle more than that.
They'll take it. And more. I think you should bi amp them, though.
I have our 12's bi amped with Adcom amps...200 wpc on the lower end and 125 wpc on the tweets and mids...
They perform very well with setup,I would not run the amps in mono if it were me...yes the speakers will handle 400 wpc with no problems,it's usually not enough power trying to overdrive speakers that will cause damage. -
Yes,they can handle 400 watts.And I`msure they would like it! I can`t remember who it was I talked to at polk customer srevice,but I was told in bi-amping these speakers I could go up tp 150 watts on the top and 500 on the bottom-yes 500.I have 100/250 going to mine and they sound much better than when I had just 250 with the jumpers in place.
why would using the amps in mono be a bad idea? would'nt be better to put more power than less?..im really not sure what would be a better option...Yamaha RX-V2600
Adcom GFA555 x 2
Polk RTi12 mains
Polk CSi3 center
Polk psw303
blue jeans cables
AR interconnects -
When you put the amps in mono mode, that effectively lessens the resistance the amps are seeing, thus making them crank out more current, meaing they're working harder at the same level and leaving you with less headroom for dynamics. If you biamp them, then they'll just be seeing the resistance the speakers present, meaning they'll be able to keep up better and have more headroom available for dynamics.
Bi-amp them as a few others here seem to be doing.
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
audiobliss wrote:When you put the amps in mono mode, that effectively lessens the resistance the amps are seeing, thus making them crank out more current, meaing they're working harder at the same level and leaving you with less headroom for dynamics. If you biamp them, then they'll just be seeing the resistance the speakers present, meaning they'll be able to keep up better and have more headroom available for dynamics.
perfect explanation....thanksYamaha RX-V2600
Adcom GFA555 x 2
Polk RTi12 mains
Polk CSi3 center
Polk psw303
blue jeans cables
AR interconnects -
Wow...perfect explanation...lemme bask in this nice, warm feeling...
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
audiobliss wrote:Wow...perfect explanation...lemme bask in this nice, warm feeling...
Careful Audiobliss... you may get sunburned.
Holydoc (Home Theatre Lover)
__________________________________________
Panasonic -50PX600U 50" Plasma
Onkyo -TX-NR901 Receiver
Oppo -Oppo 980HD Universal DVD Player
Outlaw -770 (7x200watt) Amplifier
PolkAudio - RTi12 (Left and Right)
PolkAudio - CSi5 (Center)
PolkAudio - FXi3 (Back and Surround)
SVS - PB-12/Plus (Subwoofer)
Bluejean Cables - Interconnects
Logitech Harmony 880 - Remote -
Haha. That's the truth...I'm one light-skinned red head...I know all about burning!
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
I would mono them.
From AB perspective, yes an amp is seeing only half the resistance as if it were running in stereo. Fortunately, you have twice the number of output transisters. Running in mono keeps you from having crosstalk between the channels. Additionally, when you look at the dynamic system, you will have more power and headroom in the mono configuration. If you bi-amp, you'll end up with less headroom as the bass section will always require more power. In a biamp config, you limit that volume to the 250W (or whatever your amp runs) for the lower section. Monoing the speaker allows the bass section to get the full 400W if needed. Look at it this way. Break the whole system into 4 speakers. highs L & R and lows L&R. In biamp, you limit all the speakers to 250W. In mono, any pair of high and low can use upto 400W to power either of those speaker. In a biamp config, you don't get the 250W+250W=500W. In reality you'll be getting more like 275W on musical passages.
In the end, you'll be lucky to run 35W anyway so it's all muteThere is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin -
Good point you bring up; I hadn't thought of that.
I guess it comes down to try 'em both and decide for yourself!
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
Great thread, guys. From a distortion standpoint, which method is a "cleaner" setup? Or is that a mute point? I would think one method would introduce more distortion vs. the other, regardless of dynamics. That is pure, layman's thinking, with no scientific understanding.
If I understand correctly, in mono mode, its an open channel of current and the speaker just takes what it needs for whatever part of the music requires the most wattage. In bi-amp mode, the individual speakers within the box will get a fixed wattage, regardless of those individual speaker's needs. Since a sub is more power hungry, it can just "take" what it needs in mono mode and leave the rest to the other speakers in the box. JD, perfect as well!UNIVERA
Historic Charleston SC
2 Channel:
SDA-SRS's RDO tweets
Biamped Anthem 2 SE's w/1970's NOS Siemens CCA's
Anthem Pre 2L w/E.harmonix platinum matched 6H23's
CDP- NAD C 542
HT setup:
AVR: NAD T 773
Rears: Polk LC80i
DVD: Toshiba 3109 dual tray
Subs: Velodyne and M&K
T.V.: Sony KDL-52XBR4 w/Vans Evers Clean Line Jr.
Conditioner: Panamax M5100EX
Master Bedroom Sony 40KDL-XBR3
"I love it when a plan comes together." Hannibal Smith, The A-Team -
univera wrote:Great thread, guys. From a distortion standpoint, which method is a "cleaner" setup? Or is that a mute point? I would think one method would introduce more distortion vs. the other, regardless of dynamics. That is pure, layman's thinking, with no scientific understanding.
Depending on the amp, there is no set "cleaner" setup. Mono mode is a little "sloppier" than 2 channel and 2 channel has x-talk so there you go...
As for your understanding, that's basically correct. Remember: A speaker will only pull as much power as the musical piece demands so 1,000,000 W amp wouldn't blow your speakers unless your trying to deafen the world.There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin -
I have 12s biamped, 200 on bottom Outlaw Monos and 170 on top from the AVR. I bet those things will rock with the adcoms.Shoot the jumper.....................BALLIN.............!!!!!
okay.....results.....i tried the bi-amp method with both adcoms, one for the highs and the other still on the lows...big improvement on the upper end...my reciever says it puts out 130 watts....probably putting more like 80,85 real watts into the highs....my 12's really came alive on the top end......then i tried each amp in mono and made my own jumpers out of 12gauge wire ........WOW......night and day....i never heard such beautiful sound...absolutly pleased and YES they sure like and can handle the power......thanks for all the info guys...Yamaha RX-V2600
Adcom GFA555 x 2
Polk RTi12 mains
Polk CSi3 center
Polk psw303
blue jeans cables
AR interconnects -
Told you so.... Now go back to stero mode and only use one amp and compare it to bi-amping. You'll probably be very surpised at what you here ( or don't...
) There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin -
I was hitting my pair at one time with 420 watts per, so the answer is yes, and then some.
I've seen the power meters on my Soundcraftsmen amps go to 600 Watts per channel on some transients when I am testing.
I have RTi12's and yes they can handle the power with no problems.
