Bi-amping Rotel RB985 for RTi8's
MattN03
How would I go about bi-amping my Rotel RB985 for use with RTi8's? I'm not really interested in using the Rotel for 5 channel surround just yet, since I want to hear what the RTi's would do with more juice.
Does anyone have any diagrams of how to bi-amp? I'm still confused on the deal (newbie
). How much power should I expect to get out of the Rotel in a bi-amp config? Is this amp able to be bridged? Would that be a better option? My complete system is in the sig if it matters.
Post edited by MattN03 on
Try the HTGuide forum at http://www.htguide.com/forum
They have a Club Rotel section with a bunch of pretty nice guys that are way into their Rotel gear. They helped me get things all set up right.:)
kevinThe Flea rig
Hitachi 50VG825 LCD
Rotel RSP 1066 (pre)
-flea market
B&K St-202 (mains)-flea market
Carver M 200t (x2) (center and surrounds)-flea market
Blu-Ray..PS3 (dvd player)
Polk RTA-11t-flea market
LsiC, Fxi30's
Dual SVS PC-Utra's (1 port blocked) thanks MikeC78
Behringer Feedback Destroyer-flea market
AudioAlchemy DDE v1.0 DAC-flea market
Cambridge Audio Azur 640 CDP-flea market
Signal Cable and Kimber Kable -
This is not hard and no need to go elsewhere. You need to Y your RCA preouts on your pre/pro or receiver and run a set into the fronts and rears of the amp. Then run the speaker wires off the fronts to the highs and the rears to the mids. Done and done. Enjoy!Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
Toxis wrote:This is not hard and no need to go elsewhere. You need to Y your RCA preouts on your pre/pro or receiver and run a set into the fronts and rears of the amp. Then run the speaker wires off the fronts to the highs and the rears to the mids. Done and done. Enjoy!
Ok, that sounds straight forward. Are the y connectors easy to find? With this setup, I'd be sending a total of 200 watts to each RTi8 (100 to the highs & 100 to the mids)? -
yes, you'll be essentially doubling the power. You can use any Y-adapters or just a Y-plug like these.Never kick a fresh **** on a hot day.
Ok, I have AQ Type 8 single bi-wire speaker cables for the fronts. If I bi-amp, I won't be able to use the bi-wire cables? I'd have an extra set of wires dangling around right?
