Help with matching rt35i's
EJ
EJ Posts: 42
edited June 2006 in Speakers
Greetings!
I now have rt2000p mains, cs400 center and three rt35i's for surround (l&r sides and center rear). I want to add two more speakers for 5.1 music in the rear corners which I will switch to for music only. Would RT6i"s be a good match? They have the same size midrange but the tweeters are different material.
Thanks in advance for all comments. I am open to other suggestions.
Regards
Emmett
Post edited by EJ on
  • honestaquarian
    honestaquarian Posts: 3,260
    edited June 2006
    If you trace the lineage.The RT-35i's became the RT-38's.Which were replaced by the RT-6's.That is why they have the same driver complement.
  • Skynut
    Skynut Posts: 2,967
    edited June 2006
    You already have what you need, what more are you looking for?
    you have front R/L, center, and surrounds.
    The RT2000's have a built in sub.
    What more are you trying to accomplish?
    What you have should do well for 5.1 music.
    If you are trying to get good movie 5.1 then add di-pole/bi-pole speakers to the sides like the FX500's
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • EJ
    EJ Posts: 42
    edited June 2006
    Thanks for the replies.
    What I am trying to accomplish is the best of two worlds. 6.1 for movies with the rt35i's on the side and on in the rear. For music, DVD audio and SACD 5.1 I want the speakers against the rear wall towards the corner. With my receiver I can switch them over depending on my source material.
    I am happy with the direct sound I get now from the sides but have never used di-pole/bi-poles for comparison.
    Regards
    Emmett
