(Don't) Wanna Be Startin' Something...
zombie boy 2000
Let me me preface this by saying that I am a firm believer in the power of quality IC's and cables, so I don't mean for this to be a launching pad into the same heated debate that can be found throughout the hallowed archives of this forum...
Why is it that the performance of a well-made speaker cable is not hindered by the existence of jumpers (homemade, stock, or otherwise)? Is the length between the two posts so insignificant as to render any depreciation nominal at best? Any ideas? Just curious...
Post edited by zombie boy 2000 on
It may be, but not likely with such a short run. I think brass jumper bars are horrible in general. That's why it's best to connect speaker cables to the mid/treble posts, then jumper down to the bass posts. Always run your best wire to the midrange/treble.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
... and what if the top posts are treble and the bottom midrange/bass?I never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore
I've never seen a speaker done this way---though if it were, I'd re-think my wire configuration.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Then run the cables into the treble and jumper down to mid/bass. The higher the frequency of the signal, the more likely it is to get noticeably degraded by poor quality connections.zombie boy 2000 wrote:... and what if the top posts are treble and the bottom midrange/bass?Tannoy Dimension TD10, SOTA Star Sapphire, Heathkit W4A's, McIntosh MC2100, Eddie-Current Zana Deux, Singlepower SDS, Sennheiser HD650, Audio-Technica L3000, Sony Qualia 010 -
Steve--
The monitor 70's are....
found this out when replacing the stock jumpers with DIY's.
Didn't know this was so unusual
I never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore -
Two way monitors - for example my Tyler Acoustics Taylo monitors - are often set up this way. Top posts go to the tweeter, bottom posts go to the single woofer that handles mids and bass. The manufacturer recommends jumpering down to the mid/woofer.steveinaz wrote:I've never seen a speaker done this way---though if it were, I'd re-think my wire configuration.Tannoy Dimension TD10, SOTA Star Sapphire, Heathkit W4A's, McIntosh MC2100, Eddie-Current Zana Deux, Singlepower SDS, Sennheiser HD650, Audio-Technica L3000, Sony Qualia 010 -
Of course, by default a 2-way would be that way. I thought he was speaking about a "tapered crossover" scenario. I'd probably just do a "proper" bi-wiring scheme in this case--no jumpering.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
steveinaz wrote:Of course, by default a 2-way would be that way. I thought he was speaking about a "tapered crossover" scenario. I'd probably just do a "proper" bi-wiring scheme in this case--no jumpering.
the 70's are 3-way and "cascade tapered" according to the specs....I never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore -
That's what I figured, I'd fork up the bones and bi-wire them properly.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
steveinaz wrote:That's what I figured, I'd fork up the bones and bi-wire them properly.
consider this just about a done deal...
I haven't been overly concerned with any depreciation in SQ since my jumpers and cables are both the same wire, but Signal Cable stole my heart recently... and if starting fresh, why not bi-wire? Hence, the original question.I never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore -
Agree. Go for it, Signal Cable is a bargain anyway.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Just got off the phone with Frank at Signal Cable.. and am eagerly awaiting the arrival of my classic bi-wire cables:D
It's all love now....:)
btw 5% discount is still in effectI never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore
