LSi25's with the Pioneer.....
confused1234
Does anyone recommend the LSi25's with the Pioneer Elite VSX-72TXV?
TV - Pioneer Elite 1130HD
DVD - Pioneer Elite DV-79AVi
Receiver/Preamp: - Pioneer Elite VSX-72TXV
Finally an Amp: - Sunfire Cinema Grand 200~5
Speakers
Fronts - LSi25
Center - LSiC
Surround - LSiFX
Cables: Blue Jeans Cables
NOW :eek: Gotta find a suuuuubwoofer!!:eek:
Speakers
Fronts - LSi25
Center - LSiC
Surround - LSiFX
Post edited by confused1234 on
Welcome to the forum.
Although the elite series is a little beefier receiver, it isn't rated to handle 4 ohm speakers, like the 25's.
Since you didn't ask for alternatives, I'll hold off for now. However, if you would like some opinions on other choices, myself or someone on the forum will be glad to help you.Tschüss
Zach -
I would reccomend it if you like the sound of the pioneer and used it as a preamp and had a separate power amplifier.There are two ways to argue with women. Both of them are wrong.
^+1.Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
^+2!Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Definitely get separates. The 25's are power hogs, but they sound great when you give them what they want.Home Theater In Progress
Samsung 4272
Denon 3910 Universal Player
Anthem AVM-20
Anthem Statement A5
Fronts LSI-25
Center LSI-C
Surround LSI-FX
Getting closer to complete!:D -
:eek: okiepolkie and kingkip ,
You offered alternatives. Please feel free to give me your suggestions. I really need your professional help. I did some research on the subject in other forums, but I was unaware of this forum. I purchased the LSi25s with the LSiC and the LSiFX for surrounds because I heard this setup at a local shop. They were hooked up to the Pioneer VSX-72TXV and it all sounded good. If you have suggestions to make that setup really powerful please let me know.
KennyTV - Pioneer Elite 1130HD
Receiver/Preamp: - Pioneer Elite VSX-72TXVFinally an Amp: - Sunfire Cinema Grand 200~5
Speakers
Fronts - LSi25
Center - LSiC
Surround - LSiFX
NOW :eek: Gotta find a suuuuubwoofer!!:eek: -
Hi Kenny welcome!
Go here! www.outlawaudio.com purchase one of their 5/7 channel amps as well as one of their prepros.
Then be prepared to rock & roll!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
confused1234 wrote::eek: okiepolkie and kingkip ,
Kenny
It all depends on what you like and want. Try some options out and don't just jump on something because someone told you to. Your ears need to be the judge. If you liked the sound of the Pioneer on the LSi series go with it, but check to see if they had some amps hooked up to the speakers.
The Pioneer will do great with some good amps. -
What type of budget are you looking at for your receiver/amp combination?
I would also recommend looking at Outlaw Audio for external amplifiers, or if you would like to go used, take a look at www.audiogon.com. Some of the amplifier brands to search for would be: B&K, Parasound, Outlaw, Adcom, as well as several others.
I'm glad you are willing to get good electronics to really make your LSi's shine.Tschüss
Zach -
Thank you guys forthe help but i have more questions. So I can use a receiver like the Pioneer and get a sep amp just for the mains? That receiver does have preamp outs. If I do it this way will I over power the venter and surrounds?
Speakers
Fronts - LSi25
Center - LSiC
Surround - LSiFX
Yes you can get just a separate amp for the speakers. But you should get a multi channel amp for all of the speakers since all of them are 4ohms! It's not healthy to over strain your poor receiver. Plus it will just sound better!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
What amp is recommended for the LSi polk speakers? My budget is only around $1000 so I don't have much. I am interested in used equipment.
Speakers
Fronts - LSi25
Center - LSiC
Surround - LSiFX
This will fit the bill perfectly!!! Jump on it!
http://cls.audiogon.com/cgi-bin/cls.pl?ampsmult&1152277137Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Could also get something like this and then run your rear speakers off your AVR.
When you get the itch to upgrade, get a nice 2 channel amp to run your front speakers off of and you can still use this one (its a 3 channel amp) to run your centers and back.
Just another thought (for a little less money)
Nice find CfrizzHome Theater In Progress
Samsung 4272
Anthem AVM-20
Anthem Statement A5
Fronts LSI-25
Center LSI-C
Surround LSI-FX
Thank you Musophile!:DMarantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
I think I am going with the outlaw 770. It does 250x5 with a 4ohm load. this should be good enough and I found one for around $650. Thank you guys for the great advice!!:DTV - Pioneer Elite 1130HD
Speakers
Fronts - LSi25
Center - LSiC
Surround - LSiFX
Excellent Choice. You should be able to get a decent receiver to use as a temporary preamp for $300-400, keeping everything around that $1000 mark.
Report back when you get everything set up.Tschüss
Zach -
Nice choice confused! But actually what you will be getting is this.
Power output: 200 watts RMS x 7 (all channels driven simultaneously into 8 ohms from 20 Hz to 20 kHz with less than 0.03% total harmonic distortion). 300 watts RMS x 7 @ 4 ohms.
And do post pics of everything once it is set up!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Well, I bought the Pioneer receiver (VSX-72TXV) because I was just going to use it by itself for a while. Then I decided what the hell and I started looking for the amp. So I got high priced receiver but at least it has some good features.
About the Outlaw 770, I am only going to run 5 speakers. The power should drop a little, right?TV - Pioneer Elite 1130HD
Speakers
Fronts - LSi25
Center - LSiC
Surround - LSiFX
