Why do Monitor 30's sound better than 40's
Today I went to Circuit City to give the Monitor 30 and 40's a listen to compare them because I'm looking to purchase rear speakers for my surround system. I was very confused because the 30's actually sounded better than the 40's especially with the lows and sounded clearer on the highs!?!? Can somebody explain this because the salesman couldn't. The test was done in their listening room, the wiring was the same, the speaker positions was the same, and using the same AVR.
Please Enlighten me.
Ern-Dog
Ern-Dog
Post edited by Ern Dog on
Hey Ern,
Didn't you already ask this question in another thread? Check that out as it has some responses. BTW welcome!There are two ways to argue with women. Both of them are wrong. -
Monitor 30 works better for Sourround than mains....
Monitor 40 sounds better fo mains than for surrounds....
This is the true !!!!
My current new system (step by step
A/V Receiver: YAMAHA RX-V657
DVD Player: YAMAHA DVD-S657
Main Towers: polkaudio® Monitor 50
Wiring: NeoTecH KS1007 OFC High Definition Speaker Cable ( 2 x 2.64 mm² ) -
Kingkip-
Yeah, I was hopin' to get more info...
I'm a newbie to Polk and it has only been within the last 2 years that I started putting together a surround system. Due to $$$, I've had to do it piece by piece. And now I'm down to one more piece to make the system complete. While I've got your ear, in the back of my PSW10 sub there is a switch called Phase 0 or 180. What the heck is this about? I listened to both and found just a very minute difference.
Seby-
I totally agree, funny how that works huh.
Ern-Doggie -
Ern Dog
The phase switch changes the phase of the output audio. A full phase or cycle is 360 degrees, also zero of the next wave, thus 180 is exactly half.
If you imagine a perfect sine wave (AC) it goes from zero up to it's peak, curves along it's peak, then goes below zero and does the same. If 2 waves are 180 degrees out of phase then when one of them is peaking on the positve, the other will be at it's opposite peak on the negative.
The phase switch on your sub allows you to change the waveform to the opposite of it's input. This can be useful if
- the sub is set-up in a way that it is primarily facing the speaker. This would cause the sound wave to naturally be out of phase and some of the sound waves may cancel
each other out
- the sub is set up in a way where it's waves are travelling together with the speaker waves. The waves would be in phase and you could hear overly loud sound where the waves overlap and reinforce each other.
There are many variables in a listening room, and generally you are experiencing a little bit more of one of these conditions then the other.
So...long explanation, easy answer. Try the switch in both positions and leave it in the one that provides the better sound. Usually one will sound just a bit better than the other.The Family
Polk SDA-1C's
Polk SDA-2
Polk Monitor 10B's
Polk LSI-9's
Polk Monitor 5's
Polk 5 jr's
Polk PSW-450 Sub
Polk CSI40 Center
This is pretty f***ed up right here. -
Bigger, in some cases, isn't always better. A lot of the LSi owners prefer the 7s over the 9s."SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
Is 2 sets of dipole speakers better than having a set of dipole and a set of bookshelf?CURRENT SYSTEM:
(TV) Sylvania 24"
(DVD Player) LG DVF 9900
Sony Playstation 2
(Receiver) Onkyo TX-SR503
(Front Speakers) Polk Audio Monitor 40
(Center Channel) Polk Audio CS 1
(Surround) Paradigm Cinema ADP [Dipole] (On top of Polk Audio Monitor 40)
(Subs) Pioneer CS-G9001 (Bi-wired with Fronts subwoofers only working layed down up against back of couch)
Monster Fiber Optic Cable (DVD Player to Receiver), Monster speaker wire -
Thanks Zen, great explanation. I learnt something new. I believe I have heard that out of phase expression when describing the crossing of the positive and negative during speaker hookup. Is this correct? Would this then suggest that if one was to do this to both speakers (2channel) it would not be noticed?
Also would your sub facing speakers example apply then to rears facing front if 4 channel stereo is selected or do processors automatically put one out of phase for this reason? I may be totally out to lunch on this but these were just my thoughts.
MikeModwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
Usher CP 6311
Phillips Pronto TS1000 Universal Remote -
Midnite:
Excellent question.
First off, yes if you hook your speakers up positive to negative you would have the sound 180 degrees out of phase, and yes if you did this to both you would again have them with the correct phase relationship to each other.
You should not hook your speakers up backwards however as they are designed to work optimally with the positive and negatives hooked up a certain way.
As to 5.1 channel set-ups. I can only give a laymans explanation here as the Dolby algorythms are beyond my spectrum of knowledge. I am fairly certain that all 5.1 mixes such as Dolby and pro-logic send the rear channel signals 90 degrees out of phase with the main speakers to combat phase cancellation of the signals.
Although I have never investigated it, I would assume SACD and DVD-A formats are similiar. Couple this with the fact that in a well mixed 5.1 a lot of the information going to the rear channels should be different audio then goes to the front anyway. ie a fighter plane on screen may be heard in the fronts, while his bullets he's firing are heard in the rear.
That's about the extent of my knowledge on the subject. :cool:The Family
Polk SDA-1C's
Polk SDA-2
Polk Monitor 10B's
Polk LSI-9's
Polk Monitor 5's
Polk 5 jr's
Polk PSW-450 Sub
Polk CSI40 Center
Thanks for the response Zen. I would never cross both speakers as there is no reason for it I was just speaking hypothetically so as to see if I fully understood what you were saying.
As far as front to back speaker relationship I was refering to 4 channel stereo, not really 5.1. I think with 5.1 they would not be getting the same signal and usually the rears wouldn't be near as loud as the front as well, except under "special" circumstances.
Consonance cd120T
Usher CP 6311
Is this the same reason some people prefer the R30's over the R50's? hehe
As to 4 channel stereo. If you are using a processor or decoder, it should be performing a phase shift to correct for phase cancellation.
I believe most of the older stereo's with a "B" speaker out put all the outputs out in the same phase. This means if you set them up with 2 channels in the front and 2 in the rear you were likely experiencing some level of phase cancellation from the "A" speakers up front to the "B" speakers in the rear.The Family
Polk SDA-1C's
Polk SDA-2
Polk Monitor 10B's
Polk LSI-9's
Polk Monitor 5's
Polk 5 jr's
Polk PSW-450 Sub
Polk CSI40 Center
Thanks for the info.
Ern Dog wrote:Why do Monitor 30's sound better than 40's
They are closer to a single, point-source image. Small speakers (good ones) can image like motherf$%ker.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
