Can't Get LSi7's to sound good for rock music
DForeman
DForeman Posts: 468
edited March 2006 in 2 Channel Audio
I have Polk LSi7 speakers hooked up to a Denon 2106 receiver (100w/c). The sub is a Polk PSW 303. Although jazz music sounds superb, I just can't get rock music to sound great.
I am talking about 2-channel sound here.
Any suggestions?
Parasound P5 Pre
Marantz AV 7703 Pre/Pro
Outlaw 7500 Amp
Marantz SA14s1 SACD/CD
Rega Planar 2 TT
Polk Audio Speakers: LSiM 705 Fronts, LC65FX Surround, LSiM 704c
Oppo BDP-103
Post edited by DForeman on
  • audiobliss
    audiobliss Posts: 12,518
    edited March 2006
    I would say that you're not going to get the LSi7's to sound really good for any type of music until you get an external amplifier to push 'em. Hook up one of them, and you'll be blown away by the increased performance.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • Airplay355
    Airplay355 Posts: 4,298
    edited March 2006
    Agreed...Try getting a nicer sub too.
  • McLoki
    McLoki Posts: 5,231
    edited March 2006
    External amp will help alot. Another thing to play with is the sub crossover and volume. Alot of times bass really helps define rock music and if that is not right, you just won't be able to get the impact you need to enjoy rock.
    As opposed to most music where you will lower the crossover setting to try and let the speaker play as much as possible - try and raise the crossover to get more of the bass moved to the subwoofer. (as you move the crossover up, you will be able to locate the sub by the sound so it better be in the front of your room, preferably between the LSi7's.
    It could also be just to small of a speaker for your room. (but the only LSi line you will be able to play off a reciever with even a chance of sucess)
    All ideas are just worth playing with between sessions of looking for a nice amp. :)
    Michael
  • danger boy
    danger boy Posts: 15,722
    edited March 2006
    some receivers will power the LSi's ok.. but like it was mentioned already. adding a two channel amp to power those. will make a big difference.
    PolkFest 2012, who's going>?
  • mldennison
    mldennison Posts: 307
    edited March 2006
    maybe you can give us a better description of what you think is lacking? you said jazz music sounds good so you have some idea what you are looking for here. so what is it that is wrong with your rock cd's, is it the detail, soundstage, low end, volume...
  • DForeman
    DForeman Posts: 468
    edited March 2006
    At higher volumes (-15 or so) the mids and highs start sounding somewhat distorted with a definite lack of soundstage.
    Parasound P5 Pre
    Outlaw 7500 Amp
    Rega Planar 2 TT
    Oppo BDP-103
  • 2+2
    2+2 Posts: 546
    edited March 2006
    Sounds like your reaching the limits of your AVR.....although at -15, it shouldnt be.....
    System 1: Martin Logan Vantage, Rotel RC 1070, B&K Reference 200.2, Music Hall DAC 15.2, Yamaha 2300
    System 2: LSi15 w/db840, Marantz SR8400, Rotel 1080, RM6800 (C&S), Sony X2020ES
    System 3: LSi7, Yamaha SW215, Music Hall Maven, Music Hall MMF CD25 w/627opamps
    System 4: RTi100, Harman Kardon AVR 230, Panasonic DVD
  • mldennison
    edited March 2006
    well that sounds to me like an amplification problem if things sound good at lower volumes but not so good at higher ones.
  • madmax
    madmax Posts: 12,434
    edited March 2006
    For sure, a higher powered high current 2 channel amplifier is needed. Something over a few hundred watts per channel. Also, if the lsi's are new they will sound better after about 200 hours of use. Pretty strange but it is very noticeable.
    madmax
    Vinyl, the final frontier...
  • Joey_V
    Joey_V Posts: 8,600
    edited March 2006
    Amplification problem... your 7s need more power.... or you need 9s.
    I think what you're looking for is a cleaner midrange... and the 9s have it, or if you go with higher current amplification, you will get a better balance and cohesiveness from the 7s. Rock music is very messy and very busy... the only time I've actually enjoyed rock music is on my ML, if that says anything.
  • DForeman
    DForeman Posts: 468
    edited March 2006
    The consenus seems to be to get an external amp. Any suggestions for brand and power. I don't want to spend more than $500.
    Thanks all for your help here. Appreciate it!
    Parasound P5 Pre
    Outlaw 7500 Amp
    Rega Planar 2 TT
    Oppo BDP-103
  • steveinaz
    steveinaz Posts: 19,545
    edited March 2006
    Used or possibly Outlaw amps at that price. Try to get at least 150 watts, 200watts recommended.
  • audiobliss
    edited March 2006
    Here's a list of links to manufacturers websites that make amps. If you need to stay under $500, you most definitely have to go with used. I'd keep a look out in the fea market here, and check out audiogon frequently.
    As for power, I'd recommend 200-250wpc. I wouldn't settle for any less.
    Audiosource Amplifiers
    Audiosource could be good if you're on a really tight budget. They're mostly pro amps, and so aren't really suited to home audio, much less speakers of the same caliber as the LSi series.
    AMC Amplifiers
    Outlaw Audio Products Page
    AMC and Outlaw are also good if you're on a budget, as they're more affordable new than a lot of other amps. I'd much rather use AMC or Outlaw than Audiosource.
    The rest are pretty much 'high-end', though some are obviously more so than others. With the rest of these, you're basically going to be satisfied until you seriously get into critical listening and demanding the most your system can deliver.
    Adcom Amplifiers
    NAD Electronics
    B&K Products
    Rotel Stereo Amplifiers
    Anthem
    Sunfire Amplifiers
    Parasound
    Niles
    Odyssey Audio
    Monarchy Audio
    Bryston
    Krell
    Musical Fidelity
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Joey_V
    Joey_V Posts: 8,600
    edited March 2006
    Rotel RB1070 or higher... if your receiver has preouts, you're set.
  • Joey_V
    Joey_V Posts: 8,600
    edited March 2006
    Or the Khartago.
  • McLoki
    McLoki Posts: 5,231
    edited March 2006
    at a listening distance of about 10 feet I started getting dynamic compression from my LSi7's at about 103-105db. I think that is about the design limits of the LSi7's and I never tried to push them further. (I always turned it down when I started to hear the speakers strain)
    In your case with a marginal amp (as far as pushing the 7's to their limits) I am sure you will run out of steam before that.
    Any idea what SPL's you are running when you notice it starting to strain?
    You have a bad combo of a mid-line AVR, a fairly hard to drive small speaker, and rock music (that, as stated, is not the LSi's forte - jazz, on the other hand, is).
    best of luck, but until we get more info, I think all you will get is reiterations of the first 10 or 11 posts....
    Michael
    edit - a lot of responses since I started typing this reply..... thats what I get for trying to work while on the forum. :)
  • Joey_V
    Joey_V Posts: 8,600
    edited March 2006
    Mike ^^ has some good points.. you may be hitting compression limits of your LSi7... couple that with a mediocre amp secton off your AVR and we have bad reproduction.
  • audiobliss
    edited March 2006
    Ok, I edited my list of manufacturers and added a bit more information. Hopefully it's helpful, and with any luck at all it's at least somewhat accurate! :D
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • DForeman
    DForeman Posts: 468
    edited March 2006
    Thanks Audiobliss - this is very helpful.
    And thanks to everyone else here as well.
    Cheers
    Parasound P5 Pre
    Outlaw 7500 Amp
    Rega Planar 2 TT
    Oppo BDP-103
    heiney9 Posts: 25,447
    edited March 2006
    In addition to all the other fine comments, I'd like to say that most of todays rock music is not recorded all that well. So I'm sure some of the limitations are a combo of the amplifier, driver compression and poor recording quality. Now there are some very well recorded rock albums, but a majority of them are not done very well. They are already distorted and compressed and when you try to play them loud on revealing speakers they sound like crapola. You may find even upgrading your power source, etc. you may have the same result. It's impossible to fix a poor recording unless you buy Bose :eek: :D .
  • adam2434
    adam2434 Posts: 995
    edited March 2006
    What were your speakers before the 7s?
    Maybe you're wanting a "bigger" sound than the 7s/sub combo can deliver.
    I'm not knocking the 7s in any way. I just know that bookshelf/sub combos are not everyone's cup of tea, depending on music preferences and listening habits.
    5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
    2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
    2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
    2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
    Kitchen: Sonos Play5.
  • Tour2ma
    Tour2ma Posts: 10,177
    edited March 2006
    Or at least than it is delivering...
    At the risk of being run over by the "man, you gotta have a separate amp" band-wagon, I have to ask:
    1. How are your 7's and sub set up? Are you using the Denon's x-over and sub-out, or the sub's x-over and speaker runs out of the Denon?
    2. At what frequency are you crossing over? Have you played with this setting?
    3. How did you calibrate your sub's level to work with the 7's?
    4. How big is your room?
    5. Have you played with the sub's position in the room?
    You may really need more current to the 7's, but unless you've exhausted the possibilities to optimize your existing set-up, you shouldn't reach for your wallet just yet.
    More later,
    Tour...
    Vox Copuli
  • DForeman
    DForeman Posts: 468
    edited March 2006
    1. I am using Denon's x-over and sub out.
    2. Crossing over at 80 -- tried 100 but was too much
    3. Not sure how to calibrate the sub - used Denon's auto set up function
    4. Listening area room is about 13 x 15
    5. Have moved the sub around with little success or difference
    Also
    Played with the equalizer a bit -- ended up raising the 63HZ level up 4 db which improved the overall sound.
    My system does sound good at volumes up to -20, after that the mids and highs distort.
    I am thinking of trading in the 7's for the 9's given that they have the extra mid.
    Parasound P5 Pre
    Outlaw 7500 Amp
    Rega Planar 2 TT
    Oppo BDP-103
    edited March 2006
    Dump the eq, they rarely do any good and as volume increases so does the distortion. Eq's add a lot of gain at the boosted frequencies. Still sounds like you are running out of current. If that's the case it's going to be worse with the 9's as they need even more current. If you have truely tried to optimize placement, and still get no satisfaction a seperate amp may be what's needed.
  • DForeman
    DForeman Posts: 468
    edited March 2006
    I realize I will need even more power with the LSi 9's but want a bigger speaker than the 7's. I am exchanging them now only because I am still within a 90 day window for trading up with the dealer.
    I know little about amps so will take my time to research.
    In the mean time I will enjoy lots of jazz at lower volumes on the 9's and bide my time for some loud rock 'n roll with a good amp.
    Parasound P5 Pre
    Outlaw 7500 Amp
    Rega Planar 2 TT
    Oppo BDP-103
    edited March 2006
    Sounds like a good plan for the long run.....the 9's will be very nice. Sometimes this hobby takes patience.
  • audiobliss
    edited March 2006
    Sounds like a good plan to me.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • DForeman
    DForeman Posts: 468
    edited March 2006
    Should I upgrade the PSW303 sub to say a PSW404? My listening area isn't that big 13X15. Does quality improve as you go up in this series or just louder?
    Parasound P5 Pre
    Outlaw 7500 Amp
    Rega Planar 2 TT
    Oppo BDP-103
  • McLoki
    McLoki Posts: 5,231
    edited March 2006
    For music Polk subs can be ok (although the one you have is not up to the LSi's quality.) For HT - you can do much better.
    Is there any chance if you returned the 7's and the sub you could swing the 15's? (hardest LSi speaker to drive, but that and the 25's are the best for rock music IMO).
    For 2 channel listening, no sub would be needed. If you chose to do HT at some point, you could wait to get a sub that matches the quality of your LSi's.
    I know it may be quite a bit more money, but if you are talking only a few hundred bucks for the difference between the LSi15's and the LSi9's plus a 404 for listening to rock music - I would go for the 15's. (This is personal opinion, many consider the 9's the best of the LSi line - I just consider the 15's to hold that position)
    Just throwing out another option.
    Michael
  • DForeman
    DForeman Posts: 468
    edited March 2006
    My first choice has always been to get the LSi15's but due to room configuration and size constraints I need to go with a smaller speaker.
    Thanks for your input.
    Parasound P5 Pre
    Outlaw 7500 Amp
    Rega Planar 2 TT
    Oppo BDP-103
