Budget turntable to match with LSi9's
cstpeter
cstpeter Posts: 387
edited March 2006 in 2 Channel Audio
I am eager to get into the analog world and am looking for a budget turntable to pair with my LSi9's. I currently have my sights set on a Pro-Ject 1 Xpression ($400). Any comments or recommendations? Is there a particular model that matches well with the LSi series?
Thanks everybody.
--Chris
Von Schweikert VR4-jr
Valve Audio Predator
Denon DVD-2900
PS Audio Digital Link III w/Cullen Level IV Mods
Pro-Ject Xpression w/Blue Point No. 2
Graham Slee Special Edition 2
PS Audio UPC-200
Post edited by cstpeter on
  • George Grand
    George Grand Posts: 12,258
    edited March 2006
    A turntable to match up with a certain pair of speakers.
    Look what you guys have created.
  • cstpeter
    cstpeter Posts: 387
    edited March 2006
    What's wrong with that? Do different tables have different sound characteristics? Do some blend better/worse with certain speakers? As noted, I'm just getting into this--constructive help is appreciated.
    Denon DVD-2900
    PS Audio UPC-200
    billbillw Posts: 7,558
    edited March 2006
    $400 is a "budget" TT? You can get a damn nice TT for that money, especially used.
    I think there is more of a potential synergy between the tonearm and the cartridge. The speakers and the turntable are pretty much independant if you ask me. There is a relationship between your amp/pre and the speakers that can't be denied, but I'd say just get the nicest TT/Cartridge combination for your money.
  • ohskigod
    ohskigod Posts: 6,505
    edited March 2006
    you can do used, but I also here that pro-ject is a very good turntable. I cant see there being a turntable that outright wont match with the LSi9. if it doesnt sound right, it woudl be some other reason. the match up should be fine
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • madmax
    madmax Posts: 12,434
    edited March 2006
    Ain't it great!
    madmax
    Vinyl, the final frontier...
  • shack
    shack Posts: 11,154
    edited March 2006
    Also consider the Music Hall MMF 2.1 and the Goldring GR-1.2. Both can be had for $300 ±. The GR-1.2 is the better bargain IMO.
    Yes it is.
    Also true...but used TTs may be one of the biggest crapshoots in audio. More than any other piece of gear I would want to see it (looks and operation) before I bought it. For someone "new" to turntables, I would recommend one of the "budget" TTs already mentioned in this thread. Pretty much a plug-and-play entry into the new world of turntables with not a lot to go wrong.
    edited March 2006
    Ok, just a difference of opinion on terminology. I would call the GR 1.2 and the others mentioned as "entry level" turntables, not budget. Hell, there is a cheap Sony that sells for $89, to me that's what I think of when the term budget is used.
    FYI, there is a GR-1.2 Demo at Audio Advisor for only $244. Others who have bought the demos have said they are just like new. They usually don't stay around long for that price.
    http://www.audioadvisor.com/store/productdetail.asp?sku=DMMHGR1.2
    I agree that buying a used TT without seeing it is risky. Local deals are alway best for that.
    Yes it is.
  • cstpeter
    cstpeter Posts: 387
    edited March 2006
    Thanks guys. I saw that GR 1.2 and was tempted; however, the Xpression will be only $225 at a local shop after I trade in an old pair of speakers--I'm pretty sure I'm gonna pull the trigger.
    I'm excited to get into vinyl, but have no idea what I'm doing. Sure is fun.
    Denon DVD-2900
    PS Audio UPC-200
  • cmy330go
    cmy330go Posts: 2,341
    edited March 2006
    The Xpression is a really good table for the money. Especially if you can kill two birds with one stone by trading some unwanted speakers.
    If you do end up just buying a table here is a list of ones to consider. Some of these have already been suggested by others.
    Project Debut
    Music Hall MMF-2.1 or MMF-5
    Goldring GR 1.2
    Dual CS 435
    Thorens TD-158 or TD-170
    Rega P2
    I'm sure there are more in that range that I can't think of right now.
    Welcome to the analog club! (evil laugh)
    Dave
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
  • George Grand
    edited March 2006
    Accept my apologies Peter. There is no "synergy" between a turntable and a certain pair of speakers. The desire to own a good turntable is all the "synergy" you need.
    No Max, I'm not sure it's good, no less great.
  • organ
    organ Posts: 4,969
    edited March 2006
    I've heard great things about Pro Ject. Other brands to look at would be Rega and Music Hall. Sorry, I don't know much about TT's. Just letting you know some brands that I've heard great things about.
  • DJMosfet
    DJMosfet Posts: 15
    edited March 2006
    SL-1200MK2
    Good turntables to practice on. I wouldnt mind having me one of these.:D
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited March 2006
    I dont think he wants to DJ.
    RT1
