Left and Right SDA's?
Airplay355
Airplay355 Posts: 4,298
edited March 2006 in Vintage Speakers
Are there left and right SDA's? What's the difference, and how would you go about turning a right SDA into a Left SDA. I'm talking about the 2b's I think. 1 Tweet and two mids with a PR.
Post edited by Airplay355 on
  • Ricardo
    Ricardo Posts: 10,636
    edited March 2006
    Yes there is a left and right SDA; difference I know is driver placement; the outside drivers are the "SDA" drivers, the inside drivers are the stereo drivers. Different signal goes to each set of drivers from the crossovers. Why do you ask? Do you have two left or two right speakers? As far as I know (which might be not enough...), by swapping internal with external drivers you should be able to do it. Don't know of any cabinet differences that would be an obstacle for this.
    SOPA
  • Airplay355
    edited March 2006
    Yea. I think I just won a pair of two Right channel SDA's...Don't really care because of the good price. But it would be nice to switch the drivers.
    http://cgi.ebay.com/2-Polk-Audio-Silver-Coil-Dome-Right-Channel-Speakers_W0QQitemZ5873167962QQcategoryZ3275QQrdZ1QQcmdZViewItem#ebayphotohosting
    I'd like to thank brett for bidding on them for me :)
  • Ricardo
    edited March 2006
    I am still a bit doubtfull on how can the interconnect cable connections have any impact on this, but from what I remember from rebuilding the crossovers of my SDA's, I cannot recall any difference between left/right crossover layout and how the interconnect wiring goes through them. I am pretty sure you should be good to go, but wait until others more experienced confirm this. I never understand how two right or two left speakers come together. I would also get a copy of the schematics to make sure all the internal wiring to drivers is as original; maybe the previous owner already made the swap.
    Oh...BTW, that's a STEAL....even for a same side pair :)
    SOPA
  • hoosier21
    hoosier21 Posts: 4,415
    edited March 2006
    all you need to do on a pair of 2B's is swap the the drivers and wires from one side to the other, this would be on the speaker you are using for your left channel.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • Ricardo
    edited March 2006
    Right...I meant drivers with their wires.....:)
    SOPA
  • dbnh
    dbnh Posts: 194
    edited March 2006
    Interesting question. When I purchased my SDA 1-Cs years ago (1988) from a PX in Germany, they only had one pair in stock; furthermore, the right speaker had been converted from a "left" speaker. I have no idea how they did it, but I didn't care, just had to have a pair of Polks!
  • Airplay355
    edited March 2006
    I'm pretty freakin excited :)
  • Airplay355
    edited March 2006
    So you guys are positive that's all I have to do? The crossover's aren't different or anything?
  • JCL
    JCL Posts: 168
    edited March 2006
    The crossover should be the same from one speaker to another. Call Ken in customer service if you want to be sure. Polk used to sell replacement crossovers and none of them were marked as left or right in the old price sheets for the SDA's. Link
    L600 (front), R200 (rear), R200 (rear surround), L400 (center), Sunfire HRS-10 (2)Marantz AV7706Sunfire Cinema Grand, Marantz M8077, Music Hall Stealth, Ortofon bronze cartridge, Parasound Zphono XRM, Sony UBP-X800
  • Airplay355
    edited March 2006
    Would I have issues powering these with my dual mono integrated? I'm not sure aht kind of common groud stuff I need or whatever.
  • Airplay355
    edited March 2006
    SOOOOO? Can i run these with my dual mono integrated amp or what? I don't wanna blow anything. I should be picking these up soon. Contacted the guy and he said sure come pick them up :)
  • Ricardo
    edited March 2006
    Measure resistance between the two negative posts in the amp's output; if it measures 0 ohms, you are good to go.
    SOPA
  • george daniel
    george daniel Posts: 12,096
    edited March 2006
    yep, crossovers are the same
  • Airplay355
    edited March 2006
    thanks HTrookie...you arent really a rookie lol
  • Airplay355
    edited March 2006
    I got my SDA's today. It turns out, there is a left and a right speaker so no need to go driver switching. I do however need an interconnect. It's a pin blade interconnect for SDA 2Bs, that's all i know. Where can I find one of these? Should I just make one?
    By the way, the SDAs are in pretty good condition. The cabinet on the left one is about a 7/10 because it does have some scratches on the top, and a few on the side. The right one is an 8/10 because it only has a few scratches. However, the drivers are absolutely perfect. No rust, rust, or any sign of ever being used. The woofers are still very tacky, and a dark black color. They had been left in a storage facility and auctioned off to the guy I bought them from. He didn't know anything about them and was generally happy to be rid of them. I hooked them up and they sound great, even without the interconnect. I'm as happy as a **** in the ball pit :)
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited March 2006
    Any single wire will do for a pin-blade IC. I use an RCA cable that has the ground collars cut off so that the round pin of the RCA goes into the pin hole. Works great as long as nobody messes with the connection. The blade was only used to stabilize the connection.
    VR3 Posts: 29,401
    edited March 2006
    tape/fasten a prong from a power cable to the rca connector ;)
  • Airplay355
    edited March 2006
    cool, so i just have to bust up an rca cable
  • schwarcw
    schwarcw Posts: 7,358
    edited March 2006
    Yes, carefully!;) Or just use a single wire with a crimp on pin connector on each end. You can buy two of these at Radio Shack for less than $1.
    Carl
