Using R50's as a center?
AzN_plyR
AzN_plyR Posts: 96
edited February 2006 in Speakers
Hey guys, I am running a pair of R30's as you all know and I am loving it! :D
Anyways, Can I use a single R50 as a center since it is A LOT cheaper than getting a CS1?
The R50's uses bigger woofers also, but it's much longer than a regular center.. would this be possible and correct? thanks!
Post edited by AzN_plyR on
  • AzN_plyR
    AzN_plyR Posts: 96
    come on guys haha anyone tried the R50's for a center yet!:)
  • millerman 3732
    millerman 3732 Posts: 1,488
    The Reaper uses an R50 for his center channel ,according to his system pics anyway, you can try looking in the system showcase to see how he did it.
    Casey
    H/T: Epson 6500ub
    Sony UBP-X800
    Toshiba HD-XA2 (HD-DVD, CD)
    Onkyo 805 (pre-amp)
    Outlaw 7125
    Polk RTi 10 (bi-amped)
    Polk CSi5 (bi-amped)
    Polk RTi6
    SVS PB 12 plus/2
    Velodyne SMS-1
    TV Rig: Samsung 50'' 4k display
    Polk Signa-1 Surround bar
  • AzN_plyR
    AzN_plyR Posts: 96
    will do, thanks a lot
  • ohskigod
    ohskigod Posts: 6,505
    if you can configure it in your set up (since its a floorstander) it will work perfectly fine. would you use it as a floorstander (on the floor) or would you put it on its side on top of a TV ( a large one, i hope)
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • AzN_plyR
    AzN_plyR Posts: 96
    it'll be on a TV, I put my r30 on there and it is fine, but I am guessing the R50 would be a little longer.
  • millerman 3732
    the only problm I can see is that since it is a floor stander at around 37'' the tweeter will be off set either to the left or right depending on how you set it up and it won't center the voice coming out of it to the tv, but if the tv is large enough you could move it enough to center it up, but I'am no pro so I could be wrong maybe someone else could chime in and clear this up
    Casey
    H/T: Epson 6500ub
    Sony UBP-X800
    Onkyo 805 (pre-amp)
    Outlaw 7125
    Polk RTi6
    SVS PB 12 plus/2
    Velodyne SMS-1
  • michael_w
    michael_w Posts: 2,813
    ↑ That was my thought to the subject as well. It should work fine if you can get it centered...
    Is there some crazy way you could get it to sit on the floor like it normally would? Keeping it on the floor would probably help maintain some clarity and bass extension.
  • astropuppy
    astropuppy Posts: 33
    Screw it's base into the ceiling.
  • EricT43
    EricT43 Posts: 130
    I've only seen floorstanders successfully used as center speakers in HT's with projectors or wall-mounted flat-panel displays.
    heiney9 Posts: 25,413
    I think a physically smaller speaker would work better. No need to have a 3 foot center speaker, where most is just cabinet. Small bookshelf's might be difficult to find as a "single" but it's worth a try.
