Dual center CSi3's??
MikeC78
MikeC78 Posts: 2,315
edited February 2006 in Speakers
Hello everyone...
Have a center channel problem hoping that I can rectify?
I currently have 2 RTi8's as my mains, 2 RTi8's as my rears, 2 RTi6's as my side surrounds, 2 single SVS PB12 Ultra's, and of course a Csi3 as my center. The problem is that all my other speakers are overkilling my center as I have NO room for a CSi5, but could fit 2 CSi3's side by side in my HT cabinet. Does this sound like an option, or will this kill my Pioneer 74TXVi in a 4ohm load? Appreciate the help....
Mike
Post edited by MikeC78 on
  • Larry Chanin
    Larry Chanin Posts: 601
  • MikeC78
    Thanks Larry...
    but it still doesn't seem to answer my question quit well, besides I just need to suck it up and just live with my single CSi3. Here are a couple pics of my current setup, you'll understand what I mean more? The cabinet isn't deep enough to accomidate a CSi5 which I'd like.
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    Running the centers in series for a 16 ohm load will yield the same amount of output as your single center with more headroom for volume. Running 2 in parallel would yield 3 db more for the 2nd speaker plus 3 db for the 4 ohm load gain. If your receiver could handle the 4 ohm load, this option offers much more gain.
    Few receivers really handle the 4 ohm loads well, but your mileage may vary.
  • MikeC78
    Thanks Dennis.... but now the question I'm concerned with is what I've been reading about "imaging, radiation and phase" problems with running two? This center is becoming a nightmare, just wish I had room for a darn CSi5! :(
  • Dennis Gardner
    You won't get any definitive answers regarding this until you try it yourself. Some would say that loading the center into a cabinet as you have causes more problems with the sound than adding a second.
  • Early B.
    Early B. Posts: 7,900
    This shouldn't happen if your system is calibrated correctly. Did you use an SPL meter and setup disc?
    "God grooves with tubes."
  • MikeC78
    Early...
    Yes, I used the Avia setup disc and RadioShack analog SPL meter I got from SVS. Seems like the center can't keep up with the rest of my speakers? I probably don't have something calibrated correctly as I am a rookie to this.... the receiver is quite over my head and I'm learning something new everyday, but to the best of my knowledge and according to the setup disc it's setup correctly.
