woot.com Another 61'' IN-Focus DLP w/ Monster kit -2499
Schris22
woot.com
Good I guess if you really want one....
once again no affiliation
* Screen: 61
* Aspect Ratio 16:9 wide screen
* Light System InFocus Engine, thinnest DLP RP
* Microdisplay Type DLP, HD2+ DarkChip2
* Native Resolution 720p High Definition (1280×720)
* Processes all HDTV modes 1080i, 720p, 480p, 480i
* Screen Type High-Gain, High-Resolution, Fine Pitch
* Anti-Reflective Screen
* Adaptive Video Noise Reduction
* Scan Rate Converter
* 3D Y/C Digital Frame
* 3:2 Pull Down Reverse (TruScan Digital Reality)
* Adjustable Color Temp
* Dynamic Color Stretch Circuitry
* Contrast Expand (B&W Stretch) Yes Off/Low/High
* Picture Presets Vibrant, Natural, Cinematic, Personal
* Viewing Angle 160 degrees
* Picture Power (watts)150/180 (Lamp Power)
* Broadcast Stereo w/dbx Noise Reduction
* Second Audio Program (SAP)
* SRS Labs TruSurround XT.1
* 7-Band Graphic Equalizer
* Front Speakers 6 (4 mid-range, 2 tweeter)
* Fully Enclosed Speaker System
* Total Watts 60 (15W/Chan + 30W Subwoofer)
* Integrated Subwoofer Yes 30 Watts
* Channels/Watts 2 Channels, 15 Watts Per
* Sound Logic Audio Leveler, Sound Presets 7 Modes + Personal
* Dolby Digital Pass-Through
* Tuning Capability NTSC/ATSC/DCR
* Digital Cable/Satellite Connections DTV-Link (IEEE 1394)/HDMI/HD Component
* Digital Cable Ready Yes (DCR) and CableCARD slot
* Auto Channel Search
* Channel Labeling Auto (via EPG data)
* Interactive Set-up w/ Menus
* Integrated Web Browser WIN CE v4.1 with IE v6.0
* Lighted Control Panel Back-lit Touch Sensor
* Multilingual On-Screen Display English/French/Spanish
* One-Button Launch for Inputs Yes Auto Tune
* Parental Control (V-Chip)
* Pic Memory Presets for Vid Inputs
* Picture Freeze, Picture-in-Picture Twin Tuner (Analog Only)
* TimersClock/Sleep/Turn-On
* RF Input (Antenna/Cable)2 (1 antenna, 1 cable)
* Audio/Video Inputs (Composite)4 L&R Audio, 4 Video
* Component Video Input (YPrPb)2 SYNCROSCAN. PLUS
* HDMI (High Def Multimedia Interface) 1 for 720p, 1080i, 480p
* Sub Woofer Output Yes RCA Phono
* A/V Outputs (Composite)1 Set L&R Audio + Video
* Audio Output (Coaxial/Optical)SP-DIF (Optical)
* IEEE1394 Connector2 w/2-Way DTV Link
* Broadband Connector (Ethernet RJ45) Yes
* Center Chan/Matrix Surround Output Yes 3 RCA Jacks
* Size: w/out Base: 62.24 (W) x 46.65 (H) x 6.85 (D), w/Base: 62.24 (W) x 47.91 (H) x 12.80 (D)
* Weight: w/outBase: 135.2 lbs, w/Base: 189.5 lbs
* Screen: 61
Receiver: Onkyo TX-SR502-S
DVD Player: Pioneer DV-578A-S
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
Subwoofer: 10'' Dayton 100 Watt
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
