I bypassed my polyswitches on my SRS's
candyliquor35m
candyliquor35m Posts: 2,267
edited November 2005 in Vintage Speakers
I got lazy and instead of replacing my polyswitches, I just bypassed them altogether. I hope that if I never push any of my amps past halfway that I will be safe. Come on these are supposed to be 1000 watt speakers.
I'm currently running a 100 wpc push-pull tube amp. Comments?
Would I be safer to buy the 600 wpc Sunfire to make sure I'm pushing clean power to the speakers?
Post edited by candyliquor35m on
  • Ricardo
    Ricardo Posts: 10,636
    You would be even safer by spending a few bucks in replacing the polyswitches :)
    SOPA
  • ND13
    ND13 Posts: 7,601
    Use your ears, if they don't sound right, turn the **** down :D :cool:
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • schwarcw
    schwarcw Posts: 7,358
    I by-passed my fuses on my SDA-2's. I soldered a solid 14 guage copper wire between the terminals. Why spend the money on interconnects, heavy wire, etc., if your going to put those electrons thru a fuse with a wire no thicker than a hair?
    I plan to do the same on my 2.3 polyswitches.
    Carl
    F1nut Posts: 51,783
    Well, seeing as the rest of the wiring (cap leads, etc.) aren't any thicker I think it's a moot point.
  • schwarcw
    Jesse,
    The fuse filament that came with my SDAs were much thinner than the crossover component leads. I hear what you saying, but one less very small conductor is an improvement. The polyswitches seem to be problematic. The user's equipment and listening habits should be considered. I don't want to see anyone's tweeters fried :eek:
    Carl
