Fixing warped DVD's
michael_w
michael_w Posts: 2,813
edited October 2005 in Electronics
I decided to throw in a dvd yesterday to try out my new setup. So I pulled the dvd from my cd wallet. When it started to spin the disc I heard this horrible noise so I immediatly ejected the disc. I tried a different dvd from the case and it worked fine. Turns out about three-quarters of the dvd's are all warped. There are a couple in the middle of the case that didn't get affected but I guess this POS cd wallet has been keeping a slight curve on the dvd's for a while and now they're stuck that way.
My question.... Is there any way to get these dvd's back to being flat? They're just burned copies so I'm only loosing about $10 worth of discs but I'm really pissed off because it takes a while to make them. Right now I've got them sandwiched between two heavy books in hope that over time they'll flatten back out.
Thanks,
Michael :mad:
Post edited by michael_w on
  • ledhed
    ledhed Posts: 1,088
    edited October 2005
    I think the book thing is the best answer-you could try a little heat but, I would be afraid to
    God shows his love for us in that while we were still sinners, Christ died for us. - Romans 5:8
  • michael_w
    edited October 2005
    I could try the heat thing on some of the crappy ones. (ones I don't watch and can live with loosing) Only would be what would be the best way to heat them up while pressing them flat - paper books + hot oven don't mix well :D I was thinking the oven at a really low temp would work, but again scary. I don't like putting anything I don't plan to eat after in the oven, except for that one time I had to put my snowboard boots in the oven...
  • Emlyn
    Emlyn Posts: 4,640
    edited October 2005
    Try a clothes iron on low setting (no steam), press down on a test disc under a piece of cloth just enough to warm up the plastic and make it pliable, then put one of the discs under something heavy to cool. I've never had a reason to do something like this, but I suspect it will work.
  • jwienand
    jwienand Posts: 80
    edited October 2005
    I would suggest a hair dryer. I used to work as a lot attendant at a car dealership and that is what we would use to remove stickers from used cars. Gets hot but not to hot.
  • michael_w
    edited October 2005
    I never thought of using an iron. The hair dryer did pop into my head but since I don't have one I'll have to put that off until I can make it out to my mom's house :p
    I'll go do some ironing and let ya know how it goes :D
    Thanks for the help people.
  • aaharvel
    aaharvel Posts: 4,489
    edited October 2005
    wash that SOB with soap!
    hey it worked for my Metallica BLACK disc when I was 13. =)
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • brettw22
    brettw22 Posts: 7,623
    edited October 2005
    Are you guys kidding? Replace that thing and just be done with it. There's a fine line between cheap and frugal........it makes no sense to try and iron out a warped piece of plastic with a foil layer.........
  • michael_w
    edited October 2005
    I would just replace them except for the fact that it takes me about an hour and a half to make each dvd copy. Times that by 24 discs and it's a lot more time and money than ironing them out...
    I just finished ironing the stack of dvd's and it looks like it works pretty well. Althought I wasn't able to get some of the completly flat they actually play now. I'll keep the stack in between the books for a while just to try and get them as flat as possible.
  • BrentMcGhee
    BrentMcGhee Posts: 548
    edited October 2005
    !!WOW!! it take you an hour and a half to copy a disc :eek:
    I can see why you would not want to have to do that again, what software are you using that it takes you that long. It takes me about 25min from start (ripping) to finish (burning).........
  • michael_w
    edited October 2005
    DVD Decrypter - 20 - 30 mins
    DVD Shrink - ~40 mins
    Nero to burn it - 15 mins
    + the time fiddling in between programs setting stuff up (like picking settings for dvd shrink)
    My computer isn't super fast :)
  • mldennison
    mldennison Posts: 307
    edited October 2005
    ahhh, thats not so bad, i remember back when cd burners first came out it took 20 min to rip and about 1:10 to burn! and that was just for a cd...
  • BrentMcGhee
    edited October 2005
    ahh... the good ole days
