What's the black stuff on my tube rectifier?
jrlouie
I have the Dared SL-2000A tube pre-amp which utilizes a tube rectifier as well. The Dared comes with the stock Chinese tubes and the tube rectifier that came with mine has some black char or something on the inside of it.
Any ideas what that is? Is there any negative effect?
Post edited by jrlouie on
is it burnt? like a light bulb can doELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se . -
It's called Getter flash... when they make the tube they ignite the getter to get rid of the gas left in the tube envelope.. it causes a flash on the glass and its normal
you will notice the smaller signal tubes have the flash on top where the getter is..MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
