Purchasing Rti9's Need Receiver.
portlyfella
portlyfella Posts: 2
edited August 2005 in Speakers
Hi All,
I am looking at purchasing either the HK avr235 or Onkyo 602.
Would either of these power the Rti8's? Would they sound good? I heard them on a Denon high end receiver and thought they sounded great. I just don't have the money to buy a receiver like that.
I also plan to purchase a vtf-2 subwoofer as well. This will be mostly for music and the occasional movie.
Thanks,
pf
  • Toxis
    Toxis Posts: 5,116
    edited August 2005
    The HK will have more sheer power. If you can afford it, find a Denon 2105. That'd be your best bet but it's a bit more money.
  • marker
    marker Posts: 1,084
    edited August 2005
    I'd vote for the Pioneer 1014/1015 at that price point.
  • Toxis
    Toxis Posts: 5,116
    edited August 2005
    HK will have more sheer power over the pioneer. But the Pioneer will have more options (including bi-amping).
  • ohskigod
    ohskigod Posts: 6,505
    edited August 2005
    RTi's are relativly easy to drive. I wouldnt worry about a reciever having the ability to drive them without issue. Its picking the one that sounds the best thats the issue :)
    I have little experience with home theater recievers (went right to seperates myself, since I allrwady had seperate amps). Get a reciever with preouts. Will give the reciever a much greater chance of growing with your home theater needs down the road.
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • Willow
    Willow Posts: 11,370
    edited August 2005
    FWIW I am running the 8's off a yamaha rxv-540. with 80wpc. I find it has enough juice. I do not have pre-outs, mistake ! wish I did I would add an amp. That said using a powered sub and setting the 8's to small I couldn't complain one bit.
  • jfburke
    jfburke Posts: 3
    edited August 2005
    I have a HK 335 driving Rti8's. I find it pretty good. I had to lower the treble on the receiver a bit because I found it a touch too bright, but I love the sound now. I'm hoping in the future to add an Outlaw amp to my receiver, but the 335 definitely doesn't have any trouble powering these speakers.
    Present System
    H/K 335 AVR
    Technics SL-MC409 110 CD Jukebox
    Sony DVP-NS725P DVD Player
    Sony KP-53HS30 TV
    Bell ExpressVu 9200 Dual Tuner HD PVR
    MX-500 Universal Remote
    Polk RTi8 Mains
    Polk CSi5 Center
    Polk FXi3 Surrounds
    Sony SA-WM500 Subwoofer
    Planned Upgrades
    SVS PB12-Plus subwoofer
    Outlaw 755 5-channel Amplifier
    My System
  • marker
    marker Posts: 1,084
    edited August 2005
    Not so fast there! It has been established from Pioneer reps on AVS and/or HTF that the 1014/1015 is in fact the exact same as the Elite VSX-52TX save for exterior trim, warranty period, a RS232 port, and a zone 2 feature. They even share the same sevice manual.
    Check out these specs from HTM, which, IMO, is much better than S&V's:
    http://www.hometheatermag.com/receivers/1204pioneer/index2.html
    Especially take note of: • Five channels driven into 8-ohm loads: 0.1% distortion at 115.3 watts; 1% distortion at 129.7 watts
    and: This graph shows that the VSX-52TX's left channel, from CD input to speaker output with two channels driving 8-ohm loads, reaches 0.1% distortion at 121.2 watts and 1% distortion at 143.1 watts. Into 4 ohms, the amplifier reaches 0.1% distortion at 197.0 watts and 1% distortion at 231.4 watts.
  • portlyfella
    edited August 2005
    So, I got the green light to spend a bit more.
    I like the features of the Pioneer 1014 and the Denon 2105 does seem nice, but I am not sure what would better fit my needs. Can someone give me their professional opinion? Ultimately, I will start with the two rti8's, vtf-2 (possible vtf-3) subwoofer and may will in the rear and center at a later time.
    This will go in a room that is 18ft by 20.8 ft.
    Thanks,
    pf
