SRS SDA's
Robert Scott
Robert Scott Posts: 29
edited August 2005 in Flea Market
I'm trying to sell my srs sda's again I live in Phoenix AZ. these are the speakers that Brett looked at some time ago. According to some of the people on this forum my crossovers are not working correctly when the interconnect cable is connected otherwise they play loud and clear without cable, Don't know if it's a major fix or something simple. I figure $1300.00 is a fair price. Only reason I'm selling is I have medical bills to pay for my son.
Polk:SRS-SDA's front Speakers
Rotel:RSP-985 Surround Processor
Denon:POA-2400 Amp
Post edited by Robert Scott on
  • danger boy
    danger boy Posts: 15,722
    edited July 2005
    what do they sound like? not that i am looking for sum... just curious. did someone try to upgrade the crossovers and it turned them into frankenspeakers?
    PolkFest 2012, who's going>?
  • Robert Scott
    edited July 2005
    speakers sound kick **** normal stereo, hook the cable up and you get a lot of midrange, that's how they sound to me, never heard a pair in good form so I would not know the difference.
    Denon:POA-2400 Amp
  • danger boy
    edited July 2005
    ummmmm. when i first got my SRS's. I too thought they had "to much" mid range... i hated the sound.. then it grows on you.. and now everything sounds in balance to me. Don't ask me how it happens.. it just does. now i like the sound... except the SL2000 (tweeters) can grate on your nerves.
    F1nut Posts: 51,782
    edited July 2005
    Seeing as you only have four mid drivers working in each cabinet with the cable disconnected I could see why you would think there is more mid range with the cable connected when you have all 8 per cabinet working.
  • danger boy
    edited July 2005
    Robert,
    Check your interconnect cable. I had a bad one and the left SDA drivers wouldn't fire.. so the sound was very lopsided. replace them and check the SDA cable.
    Placement in the room will also affect the mid range sound. Move them if you can away from all walls. a good 4 feet on each side. and I found that about 6 to 8 inches from the back wall works best. I placed them against the wall first.. and it sounded kind of flat.. then i moved em way out into the room.. and the sound field was weird. so i settled on about 6 inches from the back wall. and now I no longer have to much mid range bass.
  • Robert Scott
    edited August 2005
    all 8 work without the cable in, i can put my ear next to them and hear them working.
    Denon:POA-2400 Amp
  • danger boy
    edited August 2005
    they may appear to be working. but without the cable in place i don't think the SDA mid drivers will be working. I could be wrong. I've only had my SRS's for a few months.
    Someone else in here would know the correct answer. I think though if you disconnect the SDA cable.. the SDA drivers don't move. I had a tough time verifiying this myself. It appeared they were working, when in fact mine were not when i had the SDA cable unhooked.
  • dorokusai
    dorokusai Posts: 25,576
    edited August 2005
    They are moving because of the a sealed design of the cabinet. I assure you, they aren't working. They may even have a little sound....but you are simply hearing the other drivers response.
  • brettw22
    brettw22 Posts: 7,623
    edited August 2005
    Those speakers did sound incredible without the cable connected.
    If I remember correctly, with the cable connected, it sounded very hollow/echo-ish sounding (kind of like a Dance Hall effect on a AVR).
  • steveinaz
    steveinaz Posts: 19,545
    edited August 2005
    I bet I-SIG (Wes) would be interested, he's in Tucson.
  • I-SIG
    I-SIG Posts: 2,243
    edited August 2005
    PM inbound, Robert! Call me and we can arrange a meet or something!
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • Robert Scott
    edited August 2005
    Speakers Are Sold
    Thanks, Wes
    Denon:POA-2400 Amp
  • George Grand
    George Grand Posts: 12,258
    edited August 2005
    Good luck with your son Robert Scott. Hope everything is okay.
    George Grand
  • george daniel
    george daniel Posts: 12,096
    edited August 2005
    Hope all goes well with your son
