magnepan SMG's RDU $100
unc2701
unc2701 Posts: 3,587
edited June 2005 in Flea Market
http://raleigh.craigslist.org/ele/81222273.html
no affil, the woman will kill me if I bring home more speakers.
Backburner:Krell KAV-300i
Post edited by unc2701 on
  • ND13
    ND13 Posts: 7,601
    edited June 2005
    There's gotta be something wrong with those.;
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • jdhdiggs
    jdhdiggs Posts: 4,305
    edited June 2005
    Nope, not neccessarily. They are old and bottom of the line as far as mags go.
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
  • simm
    simm Posts: 575
    edited June 2005
    Are they worth $100? I will be going through Wendell this weekend and could possibly get them if still available. I have never heard maggies before.
  • ohskigod
    ohskigod Posts: 6,502
    edited June 2005
    as long as they work, they are definitly worth it. get to try out maggies on the CHEAP!
    Living Room 2 Channel -
    Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
    Upstairs 2 Channel Rig -
    Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
    Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
  • unc2701
    edited June 2005
    Yeah, I'd put 'em in the $200-$250 range- deffinitely worth it if they're working (and you're ok with the maggie concept).
  • dorokusai
    dorokusai Posts: 25,576
    edited June 2005
    I would pass....they are too old.
  • woodyjacobs
    woodyjacobs Posts: 706
    edited June 2005
    fyi...I emailed the seller and asked them if they are functional. He said yes but that one of them sounds "a little flat." Ehhh. I'll pass.
    system 1:
    Athena: AS-F1 mains, AS-C1 center, AS-B1 surrounds, AS-P400 sub, Yammie RXV-730, Rotel RB-976 driving front stage, Samsung BD3600 Blue Ray, Denon DVD2900 for sacd/cd , jbl n24awII on the deck, samsung 40" 1080p lcd
    system 2:
    XBox 360 Spherex 5.1 system, HK DVD38, Phillips CDC 926 CD changer, Phillips 32" LCD
    2 channel
    NAD 1600 pre, NAD 2400 THX amp, Phillips CDC 926, Linn extra speaks, crappy TT
  • unc2701
    edited June 2005
    Yeah, that does sound like a pass... it's not like you can swap out a driver for $30. Oh well.
  • woodyjacobs
    edited June 2005
    my thoughts exactly.
    system 1:
    system 2:
    2 channel
  • jdhdiggs
    edited June 2005
    No, but you can get some 3M glue and fix the sucker for about $5 and a couple hours of effort. All in all, if you are thinking about maggies, get the MMG and return it after 30 days if it's not your cup of tea.
  • dorokusai
    edited June 2005
    I wouldn't spend $100 on a pair of 20+ year old Magnepan, especially those in particular. Magnepans are a little trickier to buy/invest in than a conventional speaker.
    There are some that are easily fixed and some that require shipment back to the factory to the tune of 300-900 for a rebuild, no thanks.
    I concur with James, pick up some MMG's if you want to try something out, as they are IMO, one of the best values in audio and risk free.
  • maggiefan
    maggiefan Posts: 223
    edited June 2005
    Fwiw, one sounding a little flat could be just a blown fuse, the tweeter section is fused.
    Larry
