Removing SL1000's question
Loud & Clear
Well, I was told it was pretty simple to remove my SL1000's from my RTA 12C's. All I had to do was to un'clip' the wires from the tweeter and remove. Sounds easy enough. The problem is I don't see any 'clips' or any other way of pulling the wires without ripping them off. Have I been mislead, or am I blind?
Two Channel Setup:
Speakers: Wharfedale Opus 2-3
Integrated Amp: Krell S-300i
DAC: Arcam irDac
Source: iMac
Remote Control: iPad Mini
3.2 Home Theater Setup:
Fronts: Klipsch RP-160M
Center: Klipsch RP-160M
Subwoofer: SVS PB12NSD (X 2)
AVR: Yamaha Aventage RX-A2030
Blu Ray: Sony BDP-S790
TV Source: DirecTV Genie
