It's xmas sub time.
Well the holiday season is here and I'm gettin my sub for Xmas. The room to be used is about 14' X 12' and I was lookin at the SVS psb-10 and 12. From posts I've read the 10 should be fine for the room now but I am looking to buy a new house within the year and I would like a larger living room so I don't want to undershoot the sub size. If I get a larger living room can I just double up the PSb-10's in the future or will I be losing out a lot by not getting the 12's. Any help would be great.
Post edited by Pines on
Get the 12.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Subs, I beleive are a case of no possible overkill, you can buy as big as you want (assuming it fits) and if it gets to overbearing you can just turn it down. However, we can never have enough, you'll appreciate the headroom.
Matt -
I asked pretty much the same question, (2) 10`s or (1) 12.
The reply from SVS was go with the PB12-ISD/2.
My room is 14x24..Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool:
