AC line voltage, what's normal?
disneyjoe7
What's the normal line voltage if you would stick a meter in the wall outlet?
I have a strange problem in the mornings that causes my UPS of my stereo system to trip off for 40 + mins at times. So I broke out a meter and was a little shock to see 128.7 maybe higher at times. Right now reads like 125.6 or so, I was thinking something like 122 or so for 120vac.
But not sure..
But not sure..
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
Post edited by disneyjoe7 on
Call your local utility company and have them check the service comming into your home. could be a transformer problem. Most electrical appliances are designed to handle a +/- 10% deviation without any problems.
they say 112 but it is more like 120-125
Steve, your getting some decent fluctuations. Call the power company, your electronics do not like it. If they won't do anything, I'd recommend you get a voltage stabilizer.
Power fluctuates due to many variables, you'll never have accurate/rated power from a line source.
The issue you are experiencing isn't uncommon. The UPS you are using most likely has a tighter tolerance than the line is providing.
Drop the UPS unless it's a surge arrestor type, and if the stereo is affected audibly, then look into a voltage stabilizer as mentioned above. Otherwise, don't worry about it.
Electronics are made to work in a wide range of enviroments.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
Someone, I don't remember who or maybe I read it, once told me electronics do not like power fluctuations. they was joshin' me?? -
Well when my UPS is happy / not working because the AC is down / brown / or high, it's normal AC voltage is 127vac. When the UPS is pissed it's working because the line is out / or too high it works for 40mins that is to much time. So when it's pissed I think is over 129 130 131 132 ? I work 7 miles from home I check the line there and I got 119.3vac. I never see my AC line that low at my house.
So I think I need to call my Electrical Power people.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
WMC Win7 32bit HD DVR -
I call the Electric Company, I know they checked (Pulled meter when at work) but I haven't heard anything back as of yet.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
