Power cable placement
    billbillw Posts: 8,367
    PSOVLSK wrote: »
    treitz3 wrote: »
    PSOVLSK wrote: »
    I’ve developed an issue in the left channel of CDP/DAC, so I’m going to hold off on anything until I get this figured out. Hopefully I can figure out the problem without having to take it in for repair.
    If you are willing to accept help troubleshooting? PM me or start a thread about it. We'll get ya' up and running again....or at the very least, figure out where the issue is.
    Thanks Tom.
    Always willing to accept help. I may start a new thread, but I finished troubleshooting tonight and the problem is definitely the left channel on the Norma CD player/dac.
    First thing I would do is check for cold solder joints on that RCA connector (where it connects to the main board). If it's discreet wiring, the chance is less likely to be a cold solder issue. If it appeared after doing some cable swaps, the stress of changing connections could have caused a break. I've had it happen often.
