Polk Audio Monitor 10 A what's this frosting powder on basket and magnet
Hi guys, first time posting here,
So recently i buy from a guy this speakers, they sound pretty good, not distortion what so ever.
I started to investigate on this speakers, when i found out about the common problem of the shifting magnets, 3 of the 4 mid drivers produce a scratching sound when i push in with just one finger on the outside of the cone, if I push in with two or more fingers evenly no scratching sound is produce.
Once in my home i realice the speakers wherer like "gunky", i clean them up and theres no signs of watter damage on the cabinets.
So i decided to take out the driver and this is how it is, with a frosting like powder in the metal plate that sandwiches de magnet, i actually ended up taking out both of them, and they are the same.
Is this toxic? Hoy can I tell if the magnet have shift or misaligned?
Can i fix it?
Last questions, this speakers have the peerlees twitter, when I was testing them i felt air coming out of the twitter, they have the hole in the center, just wantend to know if this is normal?
Thanks in advace for all the help.
Answers
    F1nut Posts: 51,693
    I already answered this on the other forum you posted on.
  • subkron
    subkron Posts: 82
    @F1nut Can you supply the link to the answer or put it here? I have a set lying around w/this stuff, searching for white powdery didn't turn up anything definitive, thx
  • speks
    speks Posts: 3
    @subkron here's the link, but no specification on the white powder, i suspect that's it's part of the oxidation of the basket, since the magnet itself does not have corrosion.
    Maybe galvanized corrosion?
    https://audiokarma.org/forums/index.php?threads/polk-audio-monitor-10-a-frosting-like-on-basket-and-magnet.1009032/
  • Gardenstater
    Gardenstater Posts: 4,759
    edited October 2022
    The white stuff is zinc hydroxide which forms over time when the zinc coating reacts with water and air and it gradually consumes the zinc coating. Most likely to occur where humidity is high and air circulation is lacking. These speakers were probably from a humid climate like the seashore.
    https://www.orrconsteel.com.au/sites/default/files/White-Rust-White-Paper-200531.pdf
    You've got the MW6500 drivers which I have in my 1979 7Bs. Unfortunately they are more subject to voice coil rubbing as the suspensions sag with age. The clearance between the OD of the voice coil and the basket plate is much tighter than in later drivers.
    You may have incipient rubbing if there is one quadrant where, when you push on the cone it tends to rub but not the other 3 quadrants. You may or may not begin to hear distortion from time to time when you are playing certain music that is closer to the resonant frequency. It is a good sign if pushing evenly on the cone all around with 4 fingers, doesn't produce rubbing.
    It couldn't hurt to rotate the drivers 180deg from the position they have been stored in.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • speks
    speks Posts: 3
    Gardenstater thanks for the info! I'm gonna rotate the drivers 180, also clean them up. Would you suggest applying oil for prevention would be a good idea?
    F1nut Posts: 51,693
    No oil
  • boston1450
    boston1450 Posts: 7,758
    As stated. Use 2 or more fingers "evenly" so your applying pressure to woofer evenly as you push in/out to check for shifted magnets.. Using 1 finger isn't going to work.. I think you answered the question, that your woofers are fine. Which is great.. As I learned here on Forum use real Windex for woofer surrounds
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
