Does the Joule Electra LA-100 Have a Fuse?
Darned thing wouldn't power up the other day. There had been a storm, but it runs through a dedicated circuit protected at the fuse box. And the two amps on the same circuit had no issue. Just thought I'd ask before opening up the unit. Thanks, and hope everyone's well. It's been a while.
- Isaac Asimov
Hi-Fi
Cabling by Groneberg
Visuals
  • maxward
    maxward Posts: 1,699
    Check the power receptacle. That’s where my mark I is fused.
  • stretchl
    stretchl Posts: 1,334
    Thanks, Max.
    - Isaac Asimov
    Hi-Fi
    Visuals
    heiney9 Posts: 25,446
    All gear, to pass whatever electrical code to be sold commercially, will have a power line fuse, somewhere. Some are easy to access, some aren't as easy. Usually it's close to the transformer and/or on the side the power cord is on, or has been suggested in the power receptacle.
    F1nut Posts: 51,794
    It's part of the IEC inet.
    SCompRacer Posts: 9,112
    audioluvr Posts: 5,920
    Generally if that fuse fails you've got other problems.
  • stretchl
    Thanks, everyone. I’ll let you know what I find.
    Unit has run fine since I purchased it maybe five years ago until this issue.
    - Isaac Asimov
    Hi-Fi
    Visuals
