Running RTI 12's on an Active crossover...
Hey all so I had a quick question about running one of my RTI 12 speakers as three way active on three different power amps.
So I got all the drivers out and the old crossover.... I figure I will probably put the non useable crossover back in the cabinet and run all my wires from the drivers out the rear port to avoid the hassle of installing new terminals.
Anyway I was trying to figure out how I would wire the mids and lows.... I'm familiar with wiring in parallel and series and what not, but the wiring diagram said to reverse the polarity?
Any help would be great right about now, and incase you guys were wondering I am running 2 Ashly Ftx 2001, 1 Ashly Fet 2000, 1 Ashly Fet 500, 1 FTX 1500 and lastly a Peavey CS-800x. The crossover I am using for the time being is a Ashly Xr-1001 which can run three way mono, at 24/db oct. I decided if I like the sound I will grab a Ashly SC-77 stereo three way active crossover 12/db oct.
All this is being guided by my Denon AVR-x3600h....
Input and feedback on whats going on is always welcome I figure I could use the constructive criticism
    Clipdat Posts: 13,101
  • bernouski
    bernouski Posts: 8
    Clipdat wrote: »
    But why?
    cuz someone blew my crossover and I dont want to buy a new one
    treitz3 Posts: 20,274
    Most likely, it's not the entire crossover....it's probably just a resistor or a cap. Easily replaceable if you are able to do what it is you are doing.
    What doesn't work on one or both of the crossover units?
  • bernouski
    bernouski Posts: 8
    treitz3 wrote: »
    The tweeter does not work, I replaced the tweeter with a working one to no avail.
    mhardy6647 Posts: 35,501
    The polarity reversal is probably tied to the order (i.e., the phase shift) of the crossover section in question. A second order crossover introduces a 180 degree phase shift (e.g.).
    That said -- Fix the "bad" crossover. While you're at it, consider a cost-effective upgrade of the capacitors (and other 'passive' crossover components, if you wish).
    Within the crossover of the tweeter or MTM network of each speaker, are there any swollen, warped or melted caps or burnt looking resistors? These are visible tell tale signs that the component may have been compromised to the point to where they are open.
  • bernouski
    bernouski Posts: 8
    treitz3 wrote: »
    No theres no visible signs on the crossover indicating which component failed
    edited June 2022
    bernouski wrote: »
    treitz3 wrote: »
    How do you know that the problem lies in the XO and not, say, in a driver?
    Crossovers are fundamentally simple: L, C, R (inductors, capacitors, and resistors), and interconnecting wires (or printed circuit traces). Pretty straightforward to troubleshoot.
  • bernouski
    bernouski Posts: 8
    edited June 2022
    bernouski wrote: »
    treitz3 wrote: »
    checked the driver on my other RTI and multimeter read it was not working. my other RTI functions properly, sadly the tweeter did not function. Its been replaced now though
  • bernouski
    bernouski Posts: 8
    can someone post a link to which capacitors or resistors I need to purchase I cant find them on amazon
    F1nut Posts: 52,276
    Sonic Craft, Parts Connexion or Madisound.
    F1nut Posts: 52,276
    bernouski wrote: »
    treitz3 wrote: »
    Then the problem is on the crossover.
  • bernouski
    bernouski Posts: 8
    I still cant find a 100v 9.0uf capacitor.... or a 2.5 ohm 5w 5% resistor
    F1nut Posts: 52,276
    bernouski wrote: »
    As I stated on AK, the problem is R1. The cap does not need to be replaced. As I also stated get a higher wattage resistor and turn the volume level down.
    You should replace R1 in both speakers. This is a good choice, https://www.soniccraft.com/product_info.php/25-ohm-vishay-mills-mra-12-p-4634?osCsid=40c9193f628df2268f9b92a860e73e92
    Now, as an alternative, you can also go with a smaller uf cap to lessen the high frequencies as well as the possibilities of a blown tweeter. These speakers are widely known for being "bright". This will help to tame that down a bit.
    Something along the line of a 6.0uf capacitor instead of the 9.0. FWIW.
