Have someone diy audio amplifier?
I'm trying to DIY class D audio amplifier. I had a question about the design though. Since this is a single-supply class D amp, what does the low-side switch do? When the high-side is on, the voltage potential is VCC to ground, but low side just connects the speakers ground to the MOSFET ground instead of to a negative supply. Did I miss something? Thank you!
