What kind of speaker is this?
  • BlueFox
    BlueFox Posts: 14,876
    A small speaker?
    Lumin X1 file player; Sony XA-5400ES SACD; Pass XP-22 pre; X600.5 amps
  • tophatjohnny
    tophatjohnny Posts: 3,399
    Definitely a 1 W
    mhardy6647 Posts: 28,601
    edited August 2021
    VR3 wrote: »
    Need to dynamat the basket
    Put that thing in a big back-loaded horn and stand back. :#
    I think Nelson Pass's ironically-monikered Kleinhorn would be perfect.
    Given that one-watt power rating, the "Darling" single-ended 1626 amp would be perfect for power B) -- ca. 750 milliwatts.
    https://jelabs.blogspot.com/2019/07/darling-amp-je-labs-style.html
  • BlueFox wrote: »
    A small speaker?
    It is supposed to be a small horn, but I don't know what model it is.
  • Faustin wrote: »
    8 ohm?
    Yes, it says 8 ohms and 1 watt, but it doesn't say what type of speaker it is.
  • It appears to be a small cone type speaker and not a horn speaker. But from the photograph there's not much else we can determine. Are you trying to replace it? If so, what component is it used in?
    I am using a serial screen which can play audio or video, but I need to connect a speaker externally first in order to play sound.
    F1nut Posts: 46,483
    ^ I wouldn't click on that link. ^
    msg Posts: 6,759
    VR3 wrote: »
    Woh, that's cool! Don't you have stuff like this?
    msg wrote: »
    VR3 wrote: »
    well, umm... kinda.
    :blush:
  • skrol
    skrol Posts: 3,107
    So there is a use for that "Leaving Polk Audio Forum" message.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • skrol
    skrol Posts: 3,107
    VR3 wrote: »
    And JB Weld the magnet.
    Stan
    Main 2ch:
    HT:
    Other stuff:
    msg Posts: 6,759
    I was reading a little about these and found this article. A guy named Kevin Schmidt from DIY Audio built some of these Nelson Pass Kleinhorns and had them on exhibit up in Vancouver. Visitors could come in to a sound treated environment at the gallery, bringing their own music to play. There was also a R2R that played sounds from a nature area. Bet that was interesting.
    https://audiophilestyle.com/ca/reviews/kevin-schmidt-we-are-the-robots-exhibit-review-r742/
