Will my TV be able to have the RM6750 plugged into it?
Hello everyone,,
What type of connectors will the RM6750 use? Is it normal RCA or component or HDMI or what?
I'm using an LG 60" plasma tv
(http://www.newegg.com/Product/Product.aspx?Item=N82E16889005134)
And the listing for the RM6750 just says "Inputs: Spring clip speaker wire inputs" which I have no idea what that means but I'm trying to figure out if I should order this sound system or if I won't be able to use it.
I really don't know much about sound systems other than that I am sick of using the stock built in speakers of the TV, which I never expected to be good but have been dealing with for awhile
  • F1nutF1nut Posts: 41,971
    You would need an AVR to power the speakers.
Howdy, Stranger!
