Onkyo TX-RZ800 receiver- Atmos, hdmi2.2, 4k- any interest
Great receiver that is big, heavy, current. Any interest? Mint in the box with everything. I would ask $350
  • FestYboyFestYboy Posts: 3,475
    edited March 15
    I looked up the specs, but didn't see a listing for pre outs, does it have an expanded pre ut section, or dies it match the mains?
  • dbryantdbryant Posts: 518
    Yes it has pre outs for all channels
    This will come in the box with all accessories. Receiver has no issues- cosmetic or functional. This weighs about 8 pounds more than the new 800 series. The RZ line is like Onkyo’s Pioneer Elite line. Wifi and Buetooth.
    The Onkyo TX-RZ800 has eight HDMI inputs for interfacing audio and video sources and the pass-through of 3D and 4K video sources. It is also HDCP 2.2 compliant, with dedicated HDMI ports. Other connectivity options include digital optical, digital coaxial, stereo RCA inputs, and more. These interfaces allow you to connect a wide variety of source components. Its dual HDMI outputs allow you to connect to external displays. Onkyo also offers a free remote app for controlling your receiver from a smartphone or tablet. Built-in high-resolution audio support allows you to take advantage of dynamic surround sound formats like DTS-HD Master Audio and Dolby TrueHD.
     High-Current Amplifier Design
    The TX-RZ800 reproduces ultra-low-frequencies down to 5 Hz. Its high-current amplification system also enhances control of the speakers for accurate and dynamic sound.
    Realistic Audio Quality
    Wide Range Amp Technology (WRAT) prevents phase shifting by pushing the roll-off point higher than the listening level frequency. Amplifying sound without phase shift is engineered to create clear, focused, and realistic audio.
    Vector Linear Shaping Circuitry (VLSC)
    Onkyo developed Vector Linear Shaping Circuitry (VLSC) to reassemble the signal in its original form following processing. Unlike conventional filters, VLSC removes pulse noise generated in D/A conversion, allowing the sound wave to be reproduced with extremely high fidelity for a smooth analog signal. The signal's data is converted between sampling points and joined with analog vectors in real time to produce a smooth output wave form. The result is designed to be virtually noiseless and smooth while revealing the subtle nuances in music sources.
    THX Select2 Plus
    The TX-RZ800 meets the demanding and rigorous performance guidelines for THX Select2 Plus certification. To achieve this, it has to pass 2,000 tests across 75 test categories, covering 14,000 data points. THX Select2 Plus is recommended for a screen-to-seat viewing distances of 10-12'.
    DTS:X Surround
    DTS:X is an object-based surround sound technology that includes height channels to deliver a fully-immersive listening experience. DTS:X provides listeners with flexibility, immersion, and interactivity. Unlike channel-based audio, you will be able to personalize your audio experience. For example, you can turn up just the dialog within a mix. DTS:X allows you to customize to your room layout as well as control dialog and dynamic range.
    Supports Dolby Atmos Up to 5.1.2-Channels
    This format combines a channel-based audio bed with object-oriented sound to place and move specific effects around the room. This is designed to create a realistic and captivating sonic atmosphere. Sound designers and artists are free to mix in a 3D space, steering effects through surround channels and adding a seamless overhead dimension with discrete height channels. Additionally, the Dolby surround up-mixer allows for your current channel-based content (that has not been mixed for Dolby Atmos) to be expanded to fill the flexible speaker layouts of a Dolby Atmos system. Please see the manufacturer's website for DTS:X availability.
    Ready for Ultra HD
    This receiver supports HDCP 2.2 compatibility. This HDMI specification offers an increase in bandwidth (up to 18 Gb/s) to support features such as 4K at 50/60 Hz (2160p), which offer 4-times the clarity of 1080p/60 Hz video resolution, and 4:4:4 color space. This Onkyo receiver also enables the transmission of High Dynamic Range (HDR) formats, and provides enhanced picture quality by simultaneously enabling greater detail for both the dark and bright parts of an image.
    Multi-Zone Audio and Video
    The TX-RZ800 features powered zone 2 and zone 2/3 pre/line-outs for distributed audio playback, including Zone 2 digital audio and network audio output. You can control the audio content in the zones via the free remote app; play the same song in all zones using whole house mode; or enjoy a different song in each room.
    Furthermore, there is a Zone 2 HDMI output for HD video in a second Room, with Zone 2 HDMI supported on inputs 1, 2, 3, 4 & 5. Use the HDMI sub out to connect a second display in another room. This allows you to route 1080p content from the media players connected to your receiver and play it back on another TV with easy smartphone control.
    Convenient Control Options
    An RS232 input, an IR input, and a 12 Volt Trigger out give the TX-RZ800 an array of control capabilities.
    Bluetooth, AirPlay, and Wi-Fi
    The TX-RZ800 has Bluetooth, AirPlay, and Wi-Fi technologies built-in. The free Onkyo Remote app puts a range of streaming options at your fingertips, from universal hi-res audio via network-attached devices to internet streaming services to music on your smartphone and tablet. You can also wirelessly stream audio from your Bluetooth sources directly to the receiver. It also comes loaded with Spotify, Pandora, SiriusXM Internet Radio, Slacker, and TuneIn. You can select a station and search for music available on these services via the Onkyo Remote app on your smart device.
    384 kHz/32-Bit High-Grade Digital-to-Analog Converter
    This receiver incorporates a premium-quality AK4458 digital-to-analog converter (DAC) from Asahi Kasei. This DAC implements unique low-distortion filtering technologies for clear sound, that's designed to unlock the potential of any audio format, including compressed, lossless, and hi-res audio (MP3, WMA, WMA Lossless, FLAC, WAV, Ogg Vorbis, AAC, Apple Lossless, DSD 5.6 MHz, LPCM, and Dolby TrueHD).
    Amplifier
    WRAT (Wide Range Amplifier Technology)
    H.C.P.S (high current power supply) and massive high-power toroidal transformer
    Continuous 6 ohms rated and certified for 4 ohms performance
    Discrete output stage circuitry
    3-Stage inverted Darlington circuitry
    Push-pull design (Parallel)
    Independent block construction
    2 independent power supplies
    Bi-amp capability for front channels
    Processing
    32-Bit digital signal processing engine
    Dolby Decoder: Atmos, Surround
    DTS Decoder: DTS: X, DTS-HD Master Audio
    Onkyo Game Surround Modes: Rock, Sports, Action, RPG
    Theater-dimensional virtual surround
    THX processing mode
    Phase-matching bass boost
    Direct/Pure mode
    Pure direct analog path mode
    Advanced Music Optimizer (Bluetooth Included)
    Connectivity
    HDMI Support for High Dynamic Range (HDR), 3D, Audio Return Channel (ARC), Consumer Electronics Control (CEC), Deep Color, x.v.Color, LipSync, DVD-Audio, SACD, multichannel PCM
    Analog-to-HDMI upconversion
    7.2-channel analog pre-outs
    Phono input for turntable connections
    Zone 2 digital to analog audio conversion (S/PDIF, NET, USB)
    Zone 3 line out(fixed)
    Made for iPod, iPhone, iPad
    Supports Onkyo Remote App (iPod touch/iPhone and Android-powered devices)
    Internet radio capable (Pandora, Spotify, Sirius, Slacker, Aupeo!, TuneIn)
    Spotify Connect support
    Streaming audio from PC/Network (DLNA, Home Media)
    Hi-resolution streaming audio formats (Apple Lossless, DSD 2.8/5.6 MHz, Dolby TrueHD, FLAC 192/24, LPCM, Ogg Vorbis, WAV, WMA)
    Streaming audio from USB
    Additional Features
    Learning remote control
    On-screen remote programming
    Hybrid standby function (to reduce power consumption)
    Smart grid-ready
    Advanced "Home" GUI
    Graphical overlaid on-screen display (OSD) via HDMI
    Solid aluminum front panel and volume control knob
    40 FM/AM and 40 Internet radio station presets
    Onkyo-RI system control
    RIHD (Remote Interactive over HDMI)
    12V trigger
    Quote Edit
  • deronb1deronb1 Posts: 4,554
    Nice avr for the money! Shouldn't last too long.
  • ZLTFULZLTFUL Posts: 4,958
    Really wish I was ready to buy and AVR for the bar. but that's not happening until mid to late summer now. GLWS. Great AVR for the money.
  • treitz3treitz3 Posts: 12,988
    I have a friend who may be interested. Can you please post some pictures of the unit so that I can show him? Thanks,
    In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence.
    The best way to enjoy digital music reproduction is to never listen to good analogue reproduction.
    Sold
Howdy, Stranger!
