power req'mnts for surround...
pmaru77
pmaru77 Posts: 11
edited March 2004 in Speakers
I'm planning on building a surround system with Rti8's front, csi3 or 5 center, and Rti4's rear (5.1) with a self powered sub. What kind of power avr can I get away with? No need to blast loud but want to have enuf power or appreciate the speakers. Will a HK230avr work? It only has 50W and 65W for stereo (just fronts).
  • bokdaddy
    bokdaddy Posts: 176
    edited March 2004
    You should be all right with that. I'd say it depends on the size of your room, but if you say you don't need to turn it up extremely loud you should be fine. My Denon receiver is 80w (I think) and goes way louder than I could ever use right now. I'd say get your receiver from some place with a nice return policy and try it out at home.
    Home:
    Denon AVR-1803
    Polk CSi30
    Polk RTi70
    Polk RTi28
    Polk PSW-303
    Car:
    Kenwood KDC-BT945U
    RF Punch P400-4
    Polk MM6501
    Polk MM651
    RF Punch P300-1
    Boston Acoustics G312-4
  • Early B.
    Early B. Posts: 7,900
    edited March 2004
    I agree. You're fine with what you have.
    "God grooves with tubes."
  • Airplay355
    Airplay355 Posts: 4,298
    edited March 2004
    harman kardon amps are conservatively rated. that receiver will be enough for you, even if you did wnt to blast it.
