Driving SRT's (Type of amp, power level, and what they can truly handle?)
villian
villian Posts: 412
edited July 2015 in Vintage Speakers
Been thinking a lot lately about the SRT's capabilities and wanted to know what everyone else thinks about this.
Polk claims that they can handle in excess of 1,000 watts RMS on each upper half (Or "Satellite") of each tower (Which I don't doubt), but I also know from experience that they're easily driven with as few as 80 watts RMS. What's everyone's take on this? What are my fellow SRT owners using to drive their towers? Is anyone Bi-amping?
The lowers (2x 10" Subs) are driven by a 600 Watt Class A/B plate amp..correct? And the satellite towers put a 4 ohm load on whichever amp is used to drive them..correct?
My SRT towers are currently each being driven by a dedicated Crown XLS 1500 amp. They're bridged giving a claimed 1,550 watts @ 4ohms in output. I have reached 119db @30hz measured at 3m away from the speakers, just for the record. I'm sure my peak output was in excess of 140db somewhere in the 500hz to 5khz range..but I have some power conditioning issues to fix before I ever try maxing out the SRT's again.
Too many good quotes to list..waiting for some fresh ammo. :)
  • chefkungfu
    chefkungfu Posts: 638
    edited July 2015
    Hey villian, I've had mine no higher than 101db!
    From last time I remember, I may have had them slightly higher... but the bass pressure may have caused a misfire in my brain! I'm currently running adcom gfa amps, but I'm going to upgrade after my TT purchase! They are not Bi-amped, just connected from the receiver to the amp, to the control boxes, and on to the SRT's.
    I used my digital spl meter resting on a tripod from the listening position to achieve that reading. The TT purchase will happen with-in the next two to three weeks (pioneer plx1000). Then I'm on the hunt for some Carver Sunfire amps! For sure, if not, then parasound amps. The big if, should I still have funds, I would love to look around for McIntosh amp(s). But I doubt it!
    I haven't pushed them as hard as you have, I probably won't take them that high. Too scared I'll break something in the house! I also believe that the subs are powered by 300W apiece! I'm probably wrong... most of the time I'm wrong!! I'll have to check the manual.
    140db sounds really high... how are your ears? I would really be impressed if they can go that high! But I'm not sure they can! Perhaps I'm wrong! Again...
    Other proud SRT owners and previous owners will chime in.
    Frank
    SRT Seismic System with dual PSW1200's
    RT5000 x 2
    RT2000p
    CS400i
    CS350-LS
    LS F/X
    PSW650
    PSW1000 w/Dayton SPA1000
    DSW MicroPro 4000
    Adcom amps
    Pioneer Elite SC-89
    Pioneer PLX-1000 Turntable
    PS4
    XBOX One
    MIT Interconnects
    BJC
  • chefkungfu
    Also, If you want to unload your SRT's.... you know what to do!
    Frank
    RT5000 x 2
    RT2000p
    CS400i
    CS350-LS
    LS F/X
    PSW650
    DSW MicroPro 4000
    Adcom amps
    Pioneer Elite SC-89
    PS4
    XBOX One
    MIT Interconnects
    BJC
    F1nut Posts: 51,700
    They are capable of 125dB maximum, which would require about 4200 wpc.
  • chefkungfu
    ^^^ F1nut hit it right on the head!!!
    RT5000 x 2
    RT2000p
    CS400i
    CS350-LS
    LS F/X
    PSW650
    DSW MicroPro 4000
    Adcom amps
    Pioneer Elite SC-89
    PS4
    XBOX One
    MIT Interconnects
    BJC
  • villian
    villian Posts: 412
    edited July 2015
    Mine are in a 1500 cubic foot room ;)
    F1nut Posts: 51,700
    So, roughly a 14x14 room? Way too small for an SRT system. Regardless, you're not getting anywhere close to 140dB given the speakers and power.
  • nguyendot
    nguyendot Posts: 3,594
    In a home 140db is.... ridiculous. In a car that would require a very well designed box, and a thousand watts or more. A car is what, 50 cu ft for a medium SUV? In a home with 1500 cu ft, which is 30x the volume it would require something in the neighborhood of tens of thousands of watts.
    Main Surround -
  • boston1450
    boston1450 Posts: 7,758
    edited July 2015
    Louder the better :)wavz2kvj438q.jpg
    Keeps the critters away
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • skrol
    skrol Posts: 3,437
    NASCAR race is around 96dB for spectators, around 130dB in the pits.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • villian
    villian Posts: 412
    ZLTFUL wrote: »
    Decibels (dB) Degree Sound Source
    225 Deafening 12" Cannon @ 12' in front and below
    195 Deafening Saturn rocket
    180 Deafening Aircraft at take-off
    160 Deafening Ram jet
    150 Deafening Turbo jet
    140 Deafening Artillery fire
    If you are hitting a consistent and steady 140db, not only are you, excuse me for being blunt, stupid, but you are most likely close to or already legally deaf.
    Don't worry, I wear double ear protection whenever trying to max out a system. Did you really think I was dumb enough not to? Oh, and you didn't need to post the DB sound scale reference. I am not a child. I had an F/A 18 pass 60ft over my head at take off today, so I think I'm more than qualified at judging what does, and does not constitute sound pressure levels in the 130db+ range. Besides, my post mentioned that I metered 119db at 30hz, yes...with an actual DB meter, and I am only claiming to hit a higher SPL at a higher frequency. In the range of 500hz to 5khz.
    Looks like my measurements were off. Just pulled up the CAD designs of my home. My Home Theater measures 16'8" long, 10'8" wide, and 8' high. So that actually puts me at 1,280 cubic feet of volume. What makes you think that I'm "Nowhere near 140db"? I'm running nearly 11,000 watts RMS total in the theater, with a room that's 1/3 the space of what Polk states the maximum output from the SRT's was designed for. Does nobody hear actually consider the rooms effect on things? That's a big oversight for such audio minded folks. Ha. My room is giving ridiculous amounts of gain across the entire spectrum. I am actually running the SRT subs at -18db of gain compared to the rest of the setup. Yes, I have the course knob at -10db and the fine tuning knob at -8db. In the previous room they were set to 0db and +4 respectively. Nothing has changed in the setup, just the room.
  • villian
    villian Posts: 412
    Either way I'm just wondering what everyone else is pushing their SRTs with, because I'm contemplating moving up from the XLS 1500's to the XLS 2500's.
    F1nut Posts: 51,700
    villian wrote: »
    This for one thing.....
    What else can I say other than, welcome to my BOZO list.
  • villian
    villian Posts: 412
    villian wrote: »
    Don't knock it till you try it. Just saying..it's not the 80's anymore..
  • nguyendot
    10'8" wide with an SRT system? Assuming you allowed the correct spacing from adjacent walls for the mains of the SRT (3ft give or take?), that would put them like 4'8" apart?
    Also, 140db at 500hz to 5khz would mean the mains are doing that SPL. They're 89db 1w/1m. With 3100 (1550x2) watts, 2-4 ft from the walls you'd get a max of 129.9db at 1 meter. 11,200 watts to the same setup (mains only, no subs) you're still only looking at 135.4db at 1 meter. 140db requires about ~32000 watts in an ideal setting at 1 meter. Unfortunately, the mains can't take even remotely that amount.
    Main Surround -
  • nguyendot
    Sorry, got over zealous :)
    Main Surround -
  • villian
    villian Posts: 412
    nguyendot wrote: »
    So since you've accounted for all the variables, how much room gain am I getting and how is that effecting things? Also, aren't the SRTs efficiency 92db?
  • nguyendot
    89db 1w/1m.
    https://us.v-cdn.net/5021930/uploads/attachments/5/4/8/0/9/37075.pdf
    Your room gain is meaningless, you aren't getting 10.1 db of gain from your room especially at 1 meter.
    Main Surround -
  • villian
    villian Posts: 412
    What do you think is the peak SPL of the SRT system, by itself then? 120db @30hz is by no means its peak. That's simply an impressive number for comparisons sake against various other systems.
  • nguyendot
    No idea, but it's easy to say it's not anywhere near 140 especially with the power levels you're running. 20db is over 6 times doubling in power and volume.
    Main Surround -
  • Enjoyed reading this post and the only question i have is, since Polk always using the max numbers in everything they publish, how come they only calculated 120 dB SPL above 30Hz using only 1 pairs of subs and not all 3 pairs (6 subs total, SEISMIC System). Any input nguyendot? Just curious that's all.
    tonyb Posts: 33,068
    Depends on the room, you have to remember in room response will almost always be different given that speaker specs are decided in special chambers. Any of you live in a special chamber ?
    nooshinjohn Posts: 25,890
    edited November 2015
    villian wrote: »
    BS..... there is no WAY in hell that a Hornet driver flew his jet that low over a civilian population, even if it was a demonstration flight at an air show. Naval Aviator wings are too hard to earn, and being that stupid with his aircraft would ruin a career.
  • villian
    villian Posts: 412
    villian wrote: »
    Who said anything about a civilian population?
  • Gatecrasher
    Gatecrasher Posts: 1,550
    Why are you so obsessed with the decibel level? Seems pretty dumb. You do know that once you damage your hearing that's it don't you?
    There is no getting it back once it's gone.
  • villian
    villian Posts: 412
    1. Because nobody else is in the home audio world. Especially in conjunction with quality sound.
    2. Yes, I understand and have understood that since a young age. I take proper precautions to protect my hearing when possible, and do yearly exams so that I can know if anything changes. I have no desire to be deaf, so I'll work my best to prevent that. Just because I can reach an ungodly decibel level doesn't mean that I listen at that level. I just like knowing that the capability, and headroom is there. In the same way that Americans love their trucks and V8s. The rest of the world doesn't understand, but there's nothing wrong with our societies choice. It's just a preference.
