Private Messaging from a phone
Has anyone figured out how to do this yet? The message button found on a profile page magically disappears on the phone. When I go through the "New Message" feature from the inbox page, it never lets me actually select who I want to send it to. I can type the name perfectly, but once I go to a new box, it disappears.
This is the one thing about the forum that really irks me and I wish it would get fixed.
  • DSkipDSkip Posts: 16,115
    I've done that at times, but it screws everything up then. They built this to work for the phone. I shouldn't have to convert to the desktop version to do something that is a major function of the software.
    Yeah, I can actually get to a new message screen, but the recipient never saves, so I can't send PM's. The function is there, but its bugged.
  • DarqueKnightDarqueKnight Posts: 6,570
    Skip,
    I just sent you a PM from my Android phone using the mobile version of the forum.
    "So hot it burns Mice!"~DK
    "Polk SDA-SRSs are hopelessly out of date both sonically and technologically... I see no value whatsoever in older SDA speakers."~Audio Asylum Member
    "Knowledge, without understanding, is a path to failure."~DK
    "Those who irrationally rail against something or someone that is no threat to them, actually desire (or desire to be like) the thing or person they are railing against."~DK
    So apparently starting a PM with an android phone works, but with an iphone doesn't. 0 for 2 with iphones, 1 for 1 with androids.
  • NightfallNightfall Posts: 8,212
    edited July 2015
    Worked for me. Chrome on Android 5.0.2
    afterburnt wrote: »
    Village Idiot of Club Polk
  • F1nutF1nut Posts: 42,686
    Once again the cry rings out.......Bring back vBulletin!!!
  • mikeyb128mikeyb128 Posts: 2,887
    Works for me on iPhone. Took me a while to figure out. Click message box bottom left. Click new messages on top right. You then have to type in... As an example DSkip, it gives you a list of recipients with a similar name. It is then followed by an "X" to add additional recipients if required. And then send your message! Works fine on iPhone six with latest firmware.
    2 channel:
    Theater:
  • vmaxervmaxer Posts: 4,455
    mikeyb128 wrote: »
    That works on my iPhone 6 as well??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • AsSiMiLaTeDAsSiMiLaTeD Posts: 11,717
    edited July 2015
    Guys, the trick is to hit the comma key after a name. So if I just enter DSkip the list applet never appears, when I enter "DSkip," the applet never fully appears to allow me to select names but I can at least get an IM to a single person if I know their name
    Thanks Danny. That works. Bad design though.
Howdy, Stranger!
