Why are FXi 3 and 5's so hard to come by?
pjd2011
pjd2011 Posts: 49
Some may already know but I just purchased a full 5.1 set of RTi's with RTi 6's as my rears.
Naturally, I'm looking into completing the sound with surround rears. I'd like to stick with the full RTi line but I'm not having any luck finding FXi 3's or 5's anywhere! I know they'll eventually come up and I need to be patient but after doing some searching they seem to be slightly coveted.
What makes them stand out?
Computer nerd diving head first into quality audio.
    F1nut Posts: 52,406
    It's likely a case of folks keeping them while upgrading the fronts because surrounds don't need to timbre match the fronts.
    You could get the FXi A4 or A6, which will work perfectly with your speakers.
  • devani
    devani Posts: 1,497
    i love my FXi3 and it really helps with 5.1 HT sound...mine are all matched like yours...good luck with your search
    Video: LG 55LN5100/Samsung LNT4065F
    Receiver: HK AVR445
    Source: OPPO BDP-93
    HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
    2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83
