Speaker and amp 'brightness'
Sprags
Sprags Posts: 120
edited June 2014 in 2 Channel Audio
I'm reading the threads making claims about speakers and amps being too 'bright. Are these differences in 'brightness' being perceived as a comparison of a 20 watt bulb to a 60 watt bulb? If not then what is the difference?
Post edited by Sprags on
  • bobsauto49
    bobsauto49 Posts: 973
    edited June 2014
    I always perceived it as bright being high in the treble, in your face sound. Harsh
    "Everything I ever did in my life worthwhile I caught hell for"
  • dragon1952
    dragon1952 Posts: 4,907
    edited June 2014
    bobsauto49 wrote: »
    What he said.
    txcoastal1 Posts: 13,507
    edited June 2014
    IMHO there is 2 definitions of "brightness" that seem to be a bit confused, is the sound bright or forward???
    Where there is a bit of confusion (again IMHO) is a forward speaker, like my Usher MD2 are forward and play jazz, blues, and classical very well highlighting the upper end details of the genre, or the peak of Ozzy coming out bright/harsh in a Black Sabbath song.
    Now in rock/classic rock which at times lack some instrumental detail will come off bright when certain Hz are hit making the sound a bit fatiguing.
    Now one listener may not be affected or may like the effect of the bright/forward sound while others may not. I like forward in my Jazz/Blues but warm/neutral in my rock. This is the reason I have multiple systems.
    Confusing as hell but you know it when it just hits the right spot and it is a lot easier to discern the differences when you have more than one completely different systems or spend some time at shows/show rooms.
  • B Run
    B Run Posts: 1,888
    edited June 2014
    ^ +1, My ZU's were very forward speakers with most of the soundstage in front of them and yet I never considered them "bright."
  • Sprags
    Sprags Posts: 120
    edited June 2014
    So I'm listening to music through LSiM703 with my tube amp and then my SS amp that many here claim.is 'bright'. I don't hear 'bright'. What I do hear is a different dimensionality. As if instruments are more forward or more spread out. I guess I can understand harsh brightness in lo-fi components....but after a certain point ...oh well...I'm sure this will start arguments.
    edited June 2014
    I agree. LSiMs are not a bright speaker. They do have good detail for a speaker that is not, though!
    Nothing to add here, pretty much on the same page about brightness and forwardness with those above. Good discussion!
    I am a "warm" man myself. Not warm to the point of no resolution and backgrounding music but warm enough not to fatigue, but to calm and relax when needed.
    cnh
    SCompRacer Posts: 9,110
    edited June 2014
    Sprags wrote: »
    So far it looks like a discussion although we may all have a slightly different definition of bright. Improved focus, detail and resolution can sound bright to some yet excite others.
    As it was mentioned early on, systems can sounds bright when there is too much treble energy, or too much treble energy relative to the rest of the frequency range. In other words, unnatural peaking of high frequencies or lack of mid bass can make the bright word happen. A room can make things bright just as some gear can. Also, high frequencies that are compressed, confused, smeared or distorted can make for brightness.
    Main thing is if you like a certain sound quality, no worries about what others say.
    EDIT:
    Here is what Stereophile says about bright.
    "bright, brilliant The most often misused terms in audio, these describe the degree to which reproduced sound has a hard, crisp edge to it. Brightness relates to the energy content in the 4kHz-8kHz band. It is not related to output in the extreme-high-frequency range. All live sound has brightness; it is a problem only when it is excessive."
    More terms than you can shake a stick at...
    http://www.integracoustics.com/MUG/MUG/bbs/stereophile_audio-glossary.html
  • Sprags
    Sprags Posts: 120
    edited June 2014
    Last night I had my tubes connected to the 703's because that's the speaker I bought for this system and I had the SS system connected to TSi300 because that's the other speaker I have. Granted the 300's don't have the clarity and openness of the 703's but in the grand scheme of things they were ok in sound volume. I'm looking for another speaker to uses with my 100 wpc stereo integrated amp.
    Any suggestions?
    My one idea is to go with Klipsch Heresy's with the tubes because those are tube speakers and dedicate the 703's to my SS system.
